pc386 benchmark timer driver Re: Timers problem
Mike Siers mikes at poliac.com
Thu Jan 9 14:56:03 UTC 2003
Hi Joel,
I just wanted to verify something related to this timer issue.
The BSP timer subdirectory contains code for a more accurate
timer that is used by the RTEMS benchmark timing tests.
If my BSP does not need to run these tests and I do not need a
more precise timer, then I am assuming my BSP is not required
to implement the timer.
Is the more precise timer used any where else in the RTEMS core?
Or is my BSP considered incomplete without this timer?
Thanks
Mike Siers
-----Original Message-----
From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
Sent: Wednesday, January 08, 2003 3:17 PM
To: Ilian Donev
Cc: RTEMS Users
Subject: pc386 benchmark timer driver Re: Timers problem
I clarified the subject just to point out that this is a BSP driver
specific problem -- it is not related to the Timer managers in
the Classic, POSIX, or ITRON APIs.
--joel
> Hello all,
> I'm new to RTEMS world and was (finally) able to build my first RTEMS
(4.5.0) with success on a PC running Mandrake Linux.
> I installed the latest precompiled tools for Linux from the "cd-working"
directory and configured RTEMS for an i386 target, with bsp pc586 for
testing purposes on a PC.
> All the demos compiled just fine. I picked the standard "Hello world" app
and booted from a floppy using GRUB. Everything was just perfect. I tried
several other apps from the sample directory
> ( tasks, semaphores, etc ) and was pleased with the results. So far, so
good.
> Then the problem: each time I try to run an app which uses the
"Timer_Initialize " function I get the error "raw handler connection
failed".
> I recompiled RTEMS for bsp pc386, tried it again on several PCs - same
error.
> What could be the problem ?
This is a problem with this BSP's benchmark timer driver.
Does the file c/src/lib/libbsp/i386/pc386/timer/timer.c have versions of
the
function for both a pentium class CPU and a default 486 and below
version?
I suspect that if both versina re there that gcc is not defining the
expecting cpp flag to indicate the CPU model.  The code is looking
for pentium to be defined when on a 586 or above class x86 so you will
know that the "rdtsc" instruction should be used for benchmarking.
> Thank you in advance !
