Re: found MPCI Layer problem?
Francesco Poletti fpoletti at libero.it
Thu Jan 9 18:22:23 UTC 2003
Because, I don't know why but the function _Objects_Initialize_information
is never called with parameter supports_global with value true.
Francesco Poletti wrote:
> I think that I have found my trouble with MPCI layer, but now I'm not able to
> resolve it...
> The _RTEMS_tasks_Information structure,which seem to be instanziated in the file
> cpukit/rtems/include/rtems/rtems/tasks.h, isn't inizialized. In particoular the
> camp _RTEMS_tasks_Information->global_table seem to be null.Is needed a cast or
> I must inizialite this camp, if yes how and where?
Why isn't it being initialized around line 166 in
score/src/objectinitializeinformation.c
(_Objects_Initialize_information)?
Did you configure with multiprocessing enabled?
--joel
> Thanks to all Francesco
> > Hy,
> > I have seen to the function _RTEMS_tasks_MP_Process_packet in the file
> > cpukit/rtems/src/taskmp.c. as Joel suggested: all seem works well...
> > I think that the problem may be in the formulation of the packet or in the
> > object table. If anyone can help me to found the formulation of the packet and
> > the object table structure I will be very happy! :-)
> The global object table structure is defined in
> score/include/rtems/score/objectmp.h.
> The "global_table" entry in the Objects_Information control block is a
> pointer to an array of them for each object type.  So something like
> this
> in gdb
> p _RTEMS_tasks_Information.global_table[NODE]
> where NODE is the remote node number.
> You should be able to walk through _Objects_MP_Open to see it get added
> and _Objects_MP_Global_name_search to watch the search.
> The packet in question should be a SHMDR "envelope" or "header" followed
> by a packet of the structure RTEMS_tasks_MP_Packet.
> One distinct possibility is that when I reworked the object name stuff
> to better support variable length string names I messed up the MP
> portion
> of this.  If it doesn't look right when it gets to those routines above
> ping me and I will rerun the mp test suite.  I thought it had been run
> recently.  But for sure, you are at the point where it would be helpful
> to feel good. :)
> It might even be worth your time to get the powerpc/psim environment
> running to see how another working MP target behaves.
> > Tanks to all Francesco.
> > > Hy, I have booted rtems on my two arm simulator, for implementing MPCI Layer
> > > I'm using the shared memory, like this I use the driver in the shmdr
> > > dyrectory.
> > > I'm using a little test examples in which every node generate a global task
> > > and after call:
> > > rtems_task_ident( Task_name[ remote_node ], RTEMS_SEARCH_ALL_NODES,
> > > &test_tid);
> > > That function returned invalid object, I have looked into the MPCI layer using
> > > the debugger and I have seen that when the node generate the global task
> > > there is a right communication with the other node, but after the
> > > rtems_task_ident there isn't communication beetwen the node...
> > > Where the node put the Object table? Where can understand how this table
> > > function?
> > For each class of object, there is local and global object id
> > information.
> > It is maintained on each node.  The creation of that task should have
> > resulted
> > in an entry being added to the global object table for classic tasks on
> > the
> > other node.
> > See if you get to the RTEMS_TASKS_MP_ANNOUNCE_CREATE case lable in the
> > > Thanks to all Francesco.
> > Joel Sherrill, Ph.D.             Director of Research & Development
> > joel at OARcorp.com                 On-Line Applications Research
> > Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> > Support Available                (256) 722-9985
