i386 GDB Thread Commands
Wed Jan 15 21:37:11 UTC 2003
Mike Siers wrote:
> Hi,
> I am using the i386/pc386 BSP for doing some initial testing
> with the current snapshot.  I built gdb 5.2 and can successfully
> do debugging over a serial line.  My question is are there any
> commands in this build of gdb which will print out the RTEMS threads?
> The rdbg version of gdb has commands like "info threads" but this
> does not work with serial debugging.
Some of the serial stubs included with RTEMS support the thread aware
stuff
in the gdb remote debugging protocol.  I thought the i386 was the first
one to do that.
Anyway, here is a script I posted back in December that will dump the
RTEMS threads regardless of the debugger interface used.
http://www.oarcorp.com/rtems/maillistArchives/rtems-users/2002/december/msg00105.html
As I suggested then, enhancements and suggestions welcomed.
> Thanks
> Mike Siers
