debugging realtek 8139 driver
M.C.Shao shaomingchao97 at mails.tsinghua.edu.cn
Thu Jan 16 14:25:07 UTC 2003
Eric Norum <norume at aps.anl.gov>
wrote:
>The error message indicates that the sytem has run out of file/socket
>descriptors.  Assuming that this message is correct (i.e. that your
>driver is not returning an incorrect error code somewhere) you need only
>to increase the number of descriptors in the system.  In your init.c:
>#define CONFIGURE_LIBIO_MAXIMUM_FILES_DESCRIPTORS 60
>Of course, if your driver is causing the system to leak file/socket
>descriptors increasing the number will just delay the problem....
Thank you very much, and thanks to all.As you said, I have fixed this problem,and
test the 8139 driver sucessfully according to the network supplement.(Untill now,
it seems that ^_^) .
