MCP750 PCI
Kamen Penev kamen at penev.net
Tue Jan 21 20:33:51 UTC 2003
Till Straumann wrote:
> However if you want to have
> st_le32(address1, val1);
> val2=ld_le32(address2);
> executed in this order (i.e. enforce reading from address2 only after
> val1 has been stored to address1), you should probably use the
> out_xxx/in_xxx macros (which contain a 'eieio' instruction after the
> load/store).
On the 603e and, I believe, 750 families eieio is a no-op.
Kamen
