undefined reference to "stderr" "stdout" "stdin"... with libteclain add-on-packages 20030120
Thu Jan 23 19:01:15 UTC 2003
> sorry, I didn't receive that email.My campus email server is not very stable recently:(.
> I built rtems add-on packages with the "bit" shell script under the packages source directory.
> Then there must be problems with the "bit" script?
>  If I build libtecla seperately, where to specify which headers to use?
> thanks so much.
I agree with everyone who has said that you have ended up configuring
and building
somehow using the native glibc not the RTEMS newlib/libc. bit is
obsolete and should
not be used any longer.
Use configure and make directly per the build instructions at
http://www.oarcorp.com/rtemsdoc-current
and I think you be in will be in  better shape.  Something went wrong
during the configure
and build process.
