makefiles and CVS
Ralf Corsepius corsepiu at faw.uni-ulm.de
Fri Jan 24 13:33:27 UTC 2003
On Fri, 2003-01-24 at 14:21, Salman wrote:
> On Fri, 2003-01-24 at 13:01, Salman wrote:
> <snip>
> > I am now starting to modify rtems code as well, and would like to do
> > this with aid of CVS, but when importing source files, it neglects
> > Makefiles and configure scripts, has anyone experienced this problem
> > before?
> <snip>
> 1. delete all .cvsignore files from all RTEMS directories
> 2. # cvs import -I ! -m "Initial RTEMS sources v.4.5.0" rtems salman
> start
Then you're about to loose much of the benefits auto*tools provide to
you - I strongly recommend not doing what you do and to read the FAQ.
Ralf
