rtems-ss-20030128
Francesco Poletti fpoletti at libero.it
Fri Jan 31 15:45:03 UTC 2003
Hy, I have tried to build rtems for my multi arm boards but I receive
an error.I have developed It starting from arm_bare_bsp like this his
name is arm_bare_bsp. I think that's a configure error:
configure: configuring in arm_bare_bsp
configure: running /bin/sh
'../../../../../../../../rtems-ss-20030128/c/src/lib/libbsp/arm/arm_bare_bsp/configure'
--prefix=/home/poletti/rtemsmulti1
'--prefix=/home/poletti/rtemsmulti1' '--host=arm-rtems'
'--build=i686-pc-linux-gnu' '--target=arm-rtems' '--enable-maintainer'
'--enable-multiprocessing' '--enable-tests' '--enable-rtems-debug'
'--with-target-subdir=arm-rtems'
'--exec-prefix=/home/poletti/rtemsmulti1/arm-rtems'
'build_alias=i686-pc-linux-gnu' 'host_alias=arm-rtems'
'target_alias=arm-rtems' 'RTEMS_BSP=arm_bare_bsp'
'RTEMS_CPU_MODEL=arm7tdmi' 'RTEMS_BSP_FAMILY=arm_bare_bsp'
'CPU_CFLAGS=-mcpu=arm7tdmi' 'CFLAGS_OPTIMIZE_V=-O2'
'CFLAGS_DEBUG_V=-O1'
'--srcdir=../../../../../../rtems-ss-20030128/c/src/lib/libbsp'
'--cache-file=/dev/null'
'--srcdir=../../../../../../../rtems-ss-20030128/c/src/lib/libbsp/arm'
--srcdir=../../../../../../../../rtems-ss-20030128/c/src/lib/libbsp/arm/arm_bare_bsp
checking for gmake... gmake
checking for RTEMS Version... ss-20021111
checking build system type... i686-pc-linux-gnu
checking host system type... arm-unknown-rtems
checking target system type... arm-unknown-rtems
checking rtems target cpu... arm
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether gmake sets ${MAKE}... yes
checking for arm-rtems-strip... arm-rtems-strip
checking if cpu arm is supported... yes
checking whether to enable maintainer-specific portions of
Makefiles... no
checking for RTEMS_BSP... arm_bare_bsp
checking for make/custom/arm_bare_bsp.cfg... yes
checking for RTEMS_CPU_MODEL...
checking for RTEMS_BSP_FAMILY...
checking for RTEMS_BSP_CFLAGS...
checking for RTEMS_BSP_CFLAGS_OPTIMIZE_V...
checking for RTEMS_BSP_CFLAGS_DEBUG_V...
checking for RTEMS_BSP_CFLAGS_PROFILE_V...
checking if wanting multiprocessing... yes
checking whether BSP supports multiprocessing... no
configure: error: multiprocessing requested but not supported
configure: error: /bin/sh
failed for arm_bare_bsp
'../../../../../../../rtems-ss-20030128/c/src/lib/libbsp/arm/configure'
failed for arm
'../../../../../../rtems-ss-20030128/c/src/lib/libbsp/configure'
failed for lib/libbsp
gmake[2]: *** [arm_bare_bsp] Error 1
gmake[2]: Leaving directory `/home/poletti/buildmulti1/arm-rtems/c'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/home/poletti/buildmulti1/arm-rtems/c'
make: *** [all-recursive] Error 1
Thanks to all which Can help me!
Francesco
