rtems-ss-20030128
Fri Jan 31 16:58:03 UTC 2003
Francesco Poletti wrote:
> Yes but my board have yet the shmsupp directory... :-((
> My Makefile.am have shmsupp in the SUBDIRS list
> and the configure.ac had the shmupp in the Makefile list...
> I had run automake and autoconf.
> Need I to run also aclocal?
Run rtems-XXX/bootstrap in your BSP directory.  Never run the
tools by hand.  It is too error prone.
> > Hy, I have tried to build rtems for my multi arm boards but I
> receive
> > an error.I have developed It starting from arm_bare_bsp like this
> his
> > name is arm_bare_bsp. I think that's a configure error:
> > configure: configuring in arm_bare_bsp
> > configure: running /bin/sh
> '../../../../../../../../rtems-ss-20030128/c/src/lib/libbsp/arm/arm_bare_bsp/configure'
> > --prefix=/home/poletti/rtemsmulti1
> > '--prefix=/home/poletti/rtemsmulti1' '--host=arm-rtems'
> > '--build=i686-pc-linux-gnu' '--target=arm-rtems'
> '--enable-maintainer'
> > '--enable-multiprocessing' '--enable-tests' '--enable-rtems-debug'
> > '--with-target-subdir=arm-rtems'
> > '--exec-prefix=/home/poletti/rtemsmulti1/arm-rtems'
> > 'build_alias=i686-pc-linux-gnu' 'host_alias=arm-rtems'
> > 'target_alias=arm-rtems' 'RTEMS_BSP=arm_bare_bsp'
> > 'RTEMS_CPU_MODEL=arm7tdmi' 'RTEMS_BSP_FAMILY=arm_bare_bsp'
> > 'CPU_CFLAGS=-mcpu=arm7tdmi' 'CFLAGS_OPTIMIZE_V=-O2'
> > 'CFLAGS_DEBUG_V=-O1'
> > '--srcdir=../../../../../../rtems-ss-20030128/c/src/lib/libbsp'
> > '--cache-file=/dev/null'
> '--srcdir=../../../../../../../rtems-ss-20030128/c/src/lib/libbsp/arm'
> --srcdir=../../../../../../../../rtems-ss-20030128/c/src/lib/libbsp/arm/arm_bare_bsp
> > checking for gmake... gmake
> > checking for RTEMS Version... ss-20021111
> > checking build system type... i686-pc-linux-gnu
> > checking host system type... arm-unknown-rtems
> > checking target system type... arm-unknown-rtems
> > checking rtems target cpu... arm
> > checking for a BSD-compatible install... /usr/bin/install -c
> > checking whether build environment is sane... yes
> > checking for gawk... gawk
> > checking whether gmake sets ${MAKE}... yes
> > checking for arm-rtems-strip... arm-rtems-strip
> > checking if cpu arm is supported... yes
> > checking whether to enable maintainer-specific portions of
> > Makefiles... no
> > checking for RTEMS_BSP... arm_bare_bsp
> > checking for make/custom/arm_bare_bsp.cfg... yes
> > checking for RTEMS_CPU_MODEL...
> > checking for RTEMS_BSP_FAMILY...
> > checking for RTEMS_BSP_CFLAGS...
> > checking for RTEMS_BSP_CFLAGS_OPTIMIZE_V...
> > checking for RTEMS_BSP_CFLAGS_DEBUG_V...
> > checking for RTEMS_BSP_CFLAGS_PROFILE_V...
> > checking if wanting multiprocessing... yes
> > checking whether BSP supports multiprocessing... no
> > configure: error: multiprocessing requested but not supported
> > configure: error: /bin/sh
> > failed for arm_bare_bsp
> '../../../../../../../rtems-ss-20030128/c/src/lib/libbsp/arm/configure'
> > failed for arm
> > '../../../../../../rtems-ss-20030128/c/src/lib/libbsp/configure'
> > failed for lib/libbsp
> > gmake[2]: *** [arm_bare_bsp] Error 1
> > gmake[2]: Leaving directory `/home/poletti/buildmulti1/arm-rtems/c'
> > gmake[1]: *** [all-recursive] Error 1
> > gmake[1]: Leaving directory `/home/poletti/buildmulti1/arm-rtems/c'
> > make: *** [all-recursive] Error 1
> See $r/../aclocal/check-multiprocessing.m4 but right now the BSP
> is assumed to not support multiprocesssing if it does not have an
> shmsupp directory.
> Ralf has thought this was a marginal solution for a while but we
> don't have a better one.
> So add an shmsupp directory.  I know you are using the shmdr. :)
> > Thanks to all which Can help me!
> > Francesco
