rtems-ss-20030128
Ralf Corsepius corsepiu at faw.uni-ulm.de
Fri Jan 31 18:02:39 UTC 2003
Am Fre, 2003-01-31 um 17.58 schrieb Joel Sherrill:
> Francesco Poletti wrote:
> > Yes but my board have yet the shmsupp directory... :-((
> > My Makefile.am have shmsupp in the SUBDIRS list
> > and the configure.ac had the shmupp in the Makefile list...
> > I had run automake and autoconf.
> > Need I to run also aclocal?
The nominal sequence is
aclocal -I <path-to-rtems-toplevel>/aclocal
automake
autoconf
> Run rtems-XXX/bootstrap in your BSP directory.
Overkill.
If integrating/adding a BSP you need to run bootstrap once inside of
c/src/lib/libbsp/<cpu>.
Then configure a build-tree with maintainer-mode enabled (configure
--enable-maintainer-mode)
Automake then will take care about dependencies itself and will invoke
its underlaying components when needed.
>   Never run the
> tools by hand.  It is too error prone.
What?
Boys, do yourselves a favor:
Read the fschking manuals: http://sources.redhat.com/autobook
and the RTEMS FAQ.
Ralf
