m68k-rtems-gcc ICE
Wed Jan 8 23:12:28 UTC 2003
wileypob wrote:
> Hi. I was compiling ACE, and I got an internal
> compiler error from gcc (using gcc 3.2.1 with the
> patch gcc-3.2.1-rtems-20021209.diff). Should I post a
> bug report here or on gcc's GNATS system? Thanks!
You would be MUCH better off filing it on gcc's GNAT.
Please cc me on it and I will add it to the set I
track.  Please try to reduce the test case as much
as possible and make it self-contained -- use
the -E option and use the output of that.  I can then
try to duplicate the problem on m68k-elf-gcc and
track the PR.
Thanks.
> Tim Housel
> __________________________________________________
> Do you Yahoo!?
> Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
> http://mailplus.yahoo.com
