pc386 benchmark timer driver Re: Timers problem
Ilian Donev
idonev at flairbase.com
Thu Jan 9 18:38:48 UTC 2003
>What compiler version and flags are being used? I suspect it must need
>to trigger on more CPU types or a different variation of pentium
>like __pentium__.
gcc 3.2.1
../rtems-ss-20021118/configure \
--target=i386-rtems \
--prefix=/opt/rtems \
--enable-tests \
--enable-rtemsbsp="pc586" \
--enable-posix
make RTEMS_BSP=pc586
make install RTEMS_BSP=pc586
-----Original Message-----
From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
Sent: 09-January-2003 11:50
To: Ilian Donev
Cc: RTEMS Users
Subject: Re: pc386 benchmark timer driver Re: Timers problem
Ilian Donev wrote:
> Joel,
> Thanks for the quick answer.
> >Does the file c/src/lib/libbsp/i386/pc386/timer/timer.c have versions
of
> the
> >function for both a pentium class CPU and a default 486 and below
> version?
> Yes, it has versions of the function for both Pentium and 386/486 CPUs. I
> fixed the
> problem by simply adding a "#define pentium" line in the corresponding
> bsp.h. It's not a elegant solution, but it worked
> fine for me since I'm testing only on pentium machines. I just can't
figure
> out why the pentium flag has not been set.
like __pentium__.
> Regards,
> Ian
> Sent: 08-January-2003 16:17
> To: Ilian Donev
> Cc: RTEMS Users
> Subject: pc386 benchmark timer driver Re: Timers problem
> I clarified the subject just to point out that this is a BSP driver
> specific problem -- it is not related to the Timer managers in
> the Classic, POSIX, or ITRON APIs.
> --joel
> > Hello all,
> > I'm new to RTEMS world and was (finally) able to build my first RTEMS
> (4.5.0) with success on a PC running Mandrake Linux.
> > I installed the latest precompiled tools for Linux from the "cd-working"
> directory and configured RTEMS for an i386 target, with bsp pc586 for
> testing purposes on a PC.
> > All the demos compiled just fine. I picked the standard "Hello world"
app
> and booted from a floppy using GRUB. Everything was just perfect. I tried
> several other apps from the sample directory
> > ( tasks, semaphores, etc ) and was pleased with the results. So far, so
> good.
> > Then the problem: each time I try to run an app which uses the
> "Timer_Initialize " function I get the error "raw handler connection
> failed".
> > I recompiled RTEMS for bsp pc386, tried it again on several PCs - same
> error.
> > What could be the problem ?
> This is a problem with this BSP's benchmark timer driver.
> Does the file c/src/lib/libbsp/i386/pc386/timer/timer.c have versions of
> the
> version?
> I suspect that if both versina re there that gcc is not defining the
> expecting cpp flag to indicate the CPU model. The code is looking
> for pentium to be defined when on a 586 or above class x86 so you will
> know that the "rdtsc" instruction should be used for benchmarking.
> > Thank you in advance !
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
