Fw: FAT-FS HD write speed
Peter Mueller
peter.o.mueller at gmx.de
Sat Jan 11 19:15:57 UTC 2003
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Eugeny,
On Sat, 11 Jan 2003 20:26:56 +0300 (MSK)
"Eugeny S. Mints" <Eugeny.Mints at oktet.ru> wrote:
> I'll forward you the letter which describes ATA architecture offerred
> by Oktet. I've sent more letters concerning the issue in october of 2002
> to the rtems-user mailing list - please, try to look into archieve.
Ok
> Ok, but I forgot to ask about one more very significiant parameters:
> what is proiroties of your (user) task and libblock swapout task? And is
> your (user) task preemtable? (it is important because as I remember Init
> task is non-preemtable).
My init task is preemtable. As far as I saw the priority of the swap-out
task is hardcoded.
bdbuf.c:27
#define SWAPOUT_PRIORITY 15
#define SWAPOUT_STACK_SIZE (RTEMS_MINIMUM_STACK_SIZE * 2)
One of my user tasks has higher priority but does not do any work while
writing to disk.
Eugeny, what write figures do you measure when writing a dummy file to a
real ide disk? Thomas has
measured 78KByte/sec on his 68040 system with flash disk which is
significant higher than my results on
a real ide disk (5.5kb/s).
Peter
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.7 (GNU/Linux)
iD8DBQE+IG1tUzCcwYQMTJoRAtgKAKCvgBfYGxlHQfDkp5oRWm76MbdK5gCgplRy
8drwqEopD5afAdZjgmoz6ZE=
=UtG+
-----END PGP SIGNATURE-----
