anyone using EPICS baseR3.14.1 on rtems target?
M.C.Shao ShaoMingchao97 at mails.tsinghua.edu.cn
Thu Jan 23 05:44:06 UTC 2003
hi,all
When I use baseR3.14.1 on i386-rtems target, I have serious problems.The following is the configuration of my building environment:
Host:    Linux(Red Hat 8.0)
Target:    i386-rtems
RTEMS version:     ss-20021118
addon-packages version:     ss-20030120, avl-1.4.0, ncurses5.3, readline4.3 and libtecla1.4.1 included.
cross-gcc version:     gcc-3.2.1, gcc-3.2.1-rtems-20021209.diff
gcc-newlib version:     newlib1.10.0, newlib-1.10.0-rtems-20021127.diff
binutils version:     binutils-2.13.1
First I build baseR3.14.1 successfully. Next, when I compile the example application created by "makeBaseApp.pl", the errors rise up(sorry,I have to paste all of them here.):
make[3]: Entering directory `/usr/local/epics/exampleApp/testApp/src/O.RTEMS-pc386'
/opt/rtems/bin/i386-rtems-g++ -B/opt/rtems/i386-rtems/pc386/lib/ -specs bsp_specs -qrtems   -o example         -L/usr/local/epics/base/lib/RTEMS-pc386/    -u Init /opt/rtems/i386-rtems/pc386/lib/no-dpmem.rel /opt/rtems/i386-rtems/pc386/lib/no-mp.rel /opt/rtems/i386-rtems/pc386/lib/no-part.rel /opt/rtems/i386-rtems/pc386/lib/no-signal.rel /opt/rtems/i386-rtems/pc386/lib/no-rtmon.rel -Wl,-Ttext,0x100000    xxxRecord.o devXxxSoft.o dbSubExample.o example_registerRecordDeviceDriver.o exampleMain.o    -lrecIoc -lsoftDevIoc -ltestDevIoc -liocsh -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom         -ltecla_r -lncurses -lm -lrtemsCom -lrtemscpu -lCom -lm
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_tputs_putchar':
getline.o(.text+0x1d): undefined reference to `_IO_putc'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `new_GetLine':
getline.o(.text+0x43): undefined reference to `stderr'
getline.o(.text+0x6d): undefined reference to `stderr'
getline.o(.text+0x45a): undefined reference to `stderr'
getline.o(.text+0x48d): undefined reference to `stderr'
getline.o(.text+0x4c3): undefined reference to `stderr'
getline.o(.text+0x5b1): undefined reference to `stdout'
getline.o(.text+0x5b9): undefined reference to `stdin'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_bind_control_char':
getline.o(.text+0x757): undefined reference to `__ctype_b_loc'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_get_line':
getline.o(.text+0x7c2): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_override_signal_handlers':
getline.o(.text+0x9e5): undefined reference to `__errno_location'
getline.o(.text+0xa03): undefined reference to `__errno_location'
getline.o(.text+0xa21): undefined reference to `__errno_location'
getline.o(.text+0xa3c): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_restore_signal_handlers':
getline.o(.text+0xb27): undefined reference to `__errno_location'
getline.o(.text+0xb45): undefined reference to `__errno_location'
getline.o(.text+0xb60): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_signal_handler':
getline.o(.text+0xba6): undefined reference to `siglongjmp'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_raw_terminal_mode':
getline.o(.text+0xbde): undefined reference to `__errno_location'
getline.o(.text+0xc20): undefined reference to `stderr'
getline.o(.text+0xc74): undefined reference to `__errno_location'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_restore_terminal_attributes':
getline.o(.text+0xcd4): undefined reference to `__errno_location'
getline.o(.text+0xcf4): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_get_input_line':
getline.o(.text+0xff0): undefined reference to `__ctype_b_loc'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_read_character':
getline.o(.text+0x13b5): undefined reference to `__errno_location'
getline.o(.text+0x13d0): undefined reference to `stderr'
getline.o(.text+0x13fd): undefined reference to `__sigsetjmp'
getline.o(.text+0x1443): undefined reference to `__errno_location'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_check_caught_signal':
getline.o(.text+0x1689): undefined reference to `__errno_location'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_control_strings':
getline.o(.text+0x1a07): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_displayed_char_width':
getline.o(.text+0x1d84): undefined reference to `__ctype_b_loc'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_output_raw_string':
getline.o(.text+0x1e98): undefined reference to `__errno_location'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_output_control_sequence':
getline.o(.text+0x1ee1): undefined reference to `__errno_location'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_output_char':
getline.o(.text+0x2178): undefined reference to `__ctype_toupper_loc'
getline.o(.text+0x2190): undefined reference to `__ctype_b_loc'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_upcase_word':
getline.o(.text+0x2ada): undefined reference to `__ctype_b_loc'
getline.o(.text+0x2b1d): undefined reference to `__ctype_toupper_loc'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_downcase_word':
getline.o(.text+0x2bbc): undefined reference to `__ctype_b_loc'
getline.o(.text+0x2bff): undefined reference to `__ctype_tolower_loc'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_capitalize_word':
getline.o(.text+0x2d14): undefined reference to `__ctype_b_loc'
getline.o(.text+0x2d3c): undefined reference to `__ctype_toupper_loc'
getline.o(.text+0x2d43): undefined reference to `__ctype_b_loc'
getline.o(.text+0x2d6b): undefined reference to `__ctype_tolower_loc'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_complete_word':
getline.o(.text+0x3b14): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_expand_filename':
getline.o(.text+0x3cfb): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_is_word_char':
getline.o(.text+0x3fb7): undefined reference to `__ctype_b_loc'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_customize_completion':
getline.o(.text+0x4017): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_change_terminal':
getline.o(.text+0x4070): undefined reference to `stderr'
getline.o(.text+0x41c6): undefined reference to `__errno_location'
getline.o(.text+0x41e1): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `_gl_read_config_file':
getline.o(.text+0x471f): undefined reference to `stderr'
getline.o(.text+0x4771): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `_gl_read_config_string':
getline.o(.text+0x483b): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `_gl_parse_config_line':
getline.o(.text+0x4a22): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o)(.text+0x4b3b): more undefined references to `stderr' follow
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_digit_argument':
getline.o(.text+0x50b6): undefined reference to `__ctype_b_loc'
getline.o(.text+0x5121): undefined reference to `__strtol_internal'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_flush_output':
getline.o(.text+0x51e7): undefined reference to `__errno_location'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_change_editor':
getline.o(.text+0x52b0): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_change_case':
getline.o(.text+0x5405): undefined reference to `__ctype_b_loc'
getline.o(.text+0x5442): undefined reference to `__ctype_toupper_loc'
getline.o(.text+0x5449): undefined reference to `__ctype_b_loc'
getline.o(.text+0x5471): undefined reference to `__ctype_tolower_loc'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_interpret_char':
getline.o(.text+0x68d7): undefined reference to `__ctype_b_loc'
getline.o(.text+0x6921): undefined reference to `__ctype_b_loc'
getline.o(.text+0x695b): undefined reference to `__ctype_b_loc'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_configure_getline':
getline.o(.text+0x6b3a): undefined reference to `stderr'
getline.o(.text+0x6bc8): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_save_history':
getline.o(.text+0x6ceb): undefined reference to `stderr'
getline.o(.text+0x6d31): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_load_history':
getline.o(.text+0x6d89): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o)(.text+0x6dcf): more undefined references to `stderr' follow
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_event_handler':
getline.o(.text+0x70c2): undefined reference to `stdout'
getline.o(.text+0x70df): undefined reference to `__errno_location'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_call_fd_handler':
getline.o(.text+0x7250): undefined reference to `__errno_location'
getline.o(.text+0x7277): undefined reference to `__errno_location'
getline.o(.text+0x72dc): undefined reference to `__errno_location'
getline.o(.text+0x733a): undefined reference to `__errno_location'
getline.o(.text+0x7381): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_group_history':
getline.o(.text+0x73c1): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_show_history':
getline.o(.text+0x7458): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_terminal_size':
getline.o(.text+0x7508): undefined reference to `__strtol_internal'
getline.o(.text+0x755a): undefined reference to `__strtol_internal'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_trap_signal':
getline.o(.text+0x7c67): undefined reference to `stderr'
getline.o(.text+0x7cff): undefined reference to `__errno_location'
getline.o(.text+0x7d1a): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_ignore_signal':
getline.o(.text+0x7d81): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(getline.o): In function `gl_line_ended':
getline.o(.text+0x7dff): undefined reference to `__ctype_b_loc'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(keytab.o): In function `_new_KeyTab':
keytab.o(.text+0x26): undefined reference to `stderr'
keytab.o(.text+0x8d): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(keytab.o): In function `_kt_extend_table':
keytab.o(.text+0x185): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(keytab.o): In function `_kt_set_keybinding':
keytab.o(.text+0x1db): undefined reference to `stderr'
keytab.o(.text+0x21c): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(keytab.o)(.text+0x269): more undefined references to `stderr' follow
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(keytab.o): In function `_kt_set_keyfn':
keytab.o(.text+0x28e): undefined reference to `__ctype_b_loc'
keytab.o(.text+0x2ce): undefined reference to `stderr'
keytab.o(.text+0x3e2): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(keytab.o): In function `_kt_lookup_keybinding':
keytab.o(.text+0x4ff): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(keytab.o): In function `_kt_parse_keybinding_string':
keytab.o(.text+0x699): undefined reference to `__ctype_toupper_loc'
keytab.o(.text+0x728): undefined reference to `__ctype_toupper_loc'
keytab.o(.text+0x753): undefined reference to `__ctype_b_loc'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(keytab.o): In function `_kt_set_action':
keytab.o(.text+0x891): undefined reference to `stderr'
keytab.o(.text+0x8f2): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(keytab.o): In function `.L213':
keytab.o(.text+0xae8): undefined reference to `__strtol_internal'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(keytab.o): In function `_kt_add_bindings':
keytab.o(.text+0xbaa): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(freelist.o): In function `_new_FreeList':
freelist.o(.text+0x53): undefined reference to `stderr'
freelist.o(.text+0xad): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(freelist.o): In function `_del_FreeList':
freelist.o(.text+0x18c): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(strngmem.o): In function `_new_StringMem':
strngmem.o(.text+0x57): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(strngmem.o)(.text+0xf9): more undefined references to `stderr' follow
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(hash.o): In function `_new_HashNode':
hash.o(.text+0x5cd): undefined reference to `__ctype_tolower_loc'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(hash.o): In function `_find_HashBucket':
hash.o(.text+0x6e7): undefined reference to `__ctype_tolower_loc'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(hash.o): In function `_ht_lower_strcmp':
hash.o(.text+0x7b4): undefined reference to `__ctype_tolower_loc'
hash.o(.text+0x7d4): undefined reference to `__ctype_tolower_loc'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(history.o): In function `_new_GlHistory':
history.o(.text+0x2a): undefined reference to `stderr'
history.o(.text+0xbf): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(history.o): In function `_glh_add_history':
history.o(.text+0x230): undefined reference to `__ctype_b_loc'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(history.o): In function `_glh_find_backwards':
history.o(.text+0x4c5): undefined reference to `stderr'
history.o(.text+0x50f): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(history.o): In function `_glh_find_forwards':
history.o(.text+0x606): undefined reference to `stderr'
history.o(.text+0x64b): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(history.o): In function `_glh_cancel_search':
history.o(.text+0x70a): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(history.o)(.text+0x77a): more undefined references to `stderr' follow
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(history.o): In function `_glh_save_history':
history.o(.text+0xb8c): undefined reference to `__errno_location'
history.o(.text+0xc6b): undefined reference to `__errno_location'
history.o(.text+0xc89): undefined reference to `stderr'
history.o(.text+0xc9a): undefined reference to `__errno_location'
history.o(.text+0xcb8): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(history.o): In function `_glh_load_history':
history.o(.text+0xd0f): undefined reference to `stderr'
history.o(.text+0xe63): undefined reference to `__strtoul_internal'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(history.o): In function `_glh_cant_load_history':
history.o(.text+0xf51): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(history.o): In function `_glh_set_group':
history.o(.text+0xf93): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(history.o): In function `_glh_show_history':
history.o(.text+0x1191): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(pathutil.o): In function `_new_PathName':
pathutil.o(.text+0x26): undefined reference to `stderr'
pathutil.o(.text+0x77): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(pathutil.o)(.text+0x100): more undefined references to `stderr' follow
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(pathutil.o): In function `_pu_pathname_dim':
pathutil.o(.text+0x458): undefined reference to `__errno_location'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(pathutil.o): In function `_pu_path_is_dir':
pathutil.o(.text+0x4ab): undefined reference to `__xstat'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(pathutil.o): In function `_pu_path_is_file':
pathutil.o(.text+0x4f3): undefined reference to `__xstat'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(pathutil.o): In function `_pu_path_is_exe':
pathutil.o(.text+0x53e): undefined reference to `__xstat'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(pathutil.o): In function `_pu_start_of_path':
pathutil.o(.text+0x5b5): undefined reference to `stderr'
pathutil.o(.text+0x5d8): undefined reference to `__ctype_b_loc'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(pathutil.o): In function `_pu_end_of_path':
pathutil.o(.text+0x64f): undefined reference to `stderr'
pathutil.o(.text+0x689): undefined reference to `__ctype_b_loc'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(pathutil.o): In function `_pu_file_exists':
pathutil.o(.text+0x6df): undefined reference to `__xstat'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(expand.o): In function `new_ExpandFile':
expand.o(.text+0x29): undefined reference to `stderr'
expand.o(.text+0x115): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(expand.o): In function `ef_expand_file':
expand.o(.text+0x250): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(expand.o): In function `ef_list_expansions':
expand.o(.text+0xee9): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(stringrp.o): In function `_new_StringGroup':
stringrp.o(.text+0x1e): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(stringrp.o)(.text+0x45): more undefined references to `stderr' follow
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(direader.o): In function `_dr_path_is_dir':
direader.o(.text+0x301): undefined reference to `__xstat'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(homedir.o): In function `_new_HomeDir':
homedir.o(.text+0x2a): undefined reference to `stderr'
homedir.o(.text+0x58): undefined reference to `__errno_location'
homedir.o(.text+0xba): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(homedir.o): In function `_hd_lookup_home_dir':
homedir.o(.text+0x162): undefined reference to `stderr'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(homedir.o): In function `hd_getpwd':
homedir.o(.text+0x37e): undefined reference to `__xstat'
homedir.o(.text+0x397): undefined reference to `__xstat'
/opt/rtems/i386-rtems/pc386/lib/libtecla_r.a(cplfile.o): In function `_new_CompleteFile':
cplfile.o(.text+0x29): undefined reference to `stderr'
collect2: ld returned 1 exit status
make[3]: *** [example] Error 1
make[3]: Leaving directory `/usr/local/epics/exampleApp/testApp/src/O.RTEMS-pc386'
make[2]: *** [install.RTEMS-pc386] Error 2
make[2]: Leaving directory `/usr/local/epics/exampleApp/testApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/usr/local/epics/exampleApp/testApp'
make: *** [testApp.install] Error 2
I really don't know how to handle this. Anyone using EPICS base 3.14.1 on rtems target had the same problems?
All these errors are related to TECLA command line library. Are these TECLA porting errors?
Thanks for any suggestions!
best regards,
ShaoMingchao
URL: <http://lists.rtems.org/pipermail/users/attachments/20030123/82f3c3f4/attachment-0001.html>
