undefined reference to "stderr" "stdout" "stdin"... with libteclain add-on-packages 20030120
M.C.Shao
ShaoMingchao97 at mails.tsinghua.edu.cn
Thu Jan 23 07:48:45 UTC 2003
sorry, I didn't receive that email.My campus email server is not very stable recently:(.
I built rtems add-on packages with the "bit" shell script under the packages source directory.
Then there must be problems with the "bit" script?
If I build libtecla seperately, where to specify which headers to use?
thanks so much.
Shao Mingchao
"Please cc to mcshao at 21cn.com my another email box."
To: M.C.Shao
Cc: rtems-users at oarcorp.com ; joel.sherrill at OARcorp.com
Sent: Thursday, January 23, 2003 7:24 AM
Subject: Re: undefined reference to "stderr" "stdout" "stdin"... with libteclain add-on-packages 20030120
As I replied already (to your EPICS tech-talks posting), it seems that you improperly built libtecla, probably using your host compiler instead of the rtems cross compiler.
'_IO_putc' and 'stderr' are both symbols used by glibc but not by rtems/newlib.
When building libtecla, your compiler apparently used glibc headers instead
of newlibc.
URL: <http://lists.rtems.org/pipermail/users/attachments/20030123/dbd00d24/attachment-0001.html>
