Need a hint on GNAT/RTEMS
Steve steved94 at attbi.com
Wed Jan 29 05:39:53 UTC 2003
----- Original Message -----
To: "Steve" <steved94 at attbi.com>
Cc: "RTEMS List" <rtems-users at OARcorp.com>
Sent: Tuesday, January 28, 2003 6:51 PM
Subject: Re: Need a hint on GNAT/RTEMS
> Are there any examples in your RTEMS source?
I've been looking for an example in the RTEMS source but haven't been able
to find one.  Maybe it's there but I am just missing it?
Here is the source file I'm attempting to compile:
with Ada.Text_Io;
procedure hello is
  package Text_io renames Ada.Text_io;
begin
  Text_Io.Put_Line( "*** WELCOME TO RTEMS ***" );
  Text_Io.Put_Line( "From GNAT/RTEMS" );
  Text_Io.Put_Line( "***" );
  delay 5.0;
end hello;
When I try using i386-rtems-gnatmake hello I get a bunch of error messages:
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/adalib/libgnat.a(cstreams.o): In
function `__gnat_full_name':
/opt/usr2/usr_src_redhat_BUILD/i386-rtems-gcc-newlib/build/gcc/ada/rts/cstre
ams.c:228: undefined reference to `getcwd'
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/adalib/libgnat.a(sysdep.o): In
function `__gnat_ttyname':
/opt/usr2/usr_src_redhat_BUILD/i386-rtems-gcc-newlib/build/gcc/ada/rts/sysde
p.c:284: undefined reference to `ttyname'
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/adalib/libgnat.a(init.o): In
function `__gnat_initialize':
/opt/usr2/usr_src_redhat_BUILD/i386-rtems-gcc-newlib/build/gcc/ada/rts/init.
c:1656: undefined reference to `__gnat_install_handler'
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(ex
it.o): In function `exit':
/usr/src/redhat/BUILD/i386-rtems-gcc-newlib/build/i386-rtems/newlib/libc/std
lib/../../../../../gcc-3.2.1/newlib/libc/stdlib/exit.c:70: undefined
reference to `_exit'
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(fc
lose.o): In function `fclose':
io/../../../../../gcc-3.2.1/newlib/libc/stdio/fclose.c:77: undefined
reference to `_free_r'
io/../../../../../gcc-3.2.1/newlib/libc/stdio/fclose.c:79: undefined
io/../../../../../gcc-3.2.1/newlib/libc/stdio/fclose.c:75: undefined
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(fi
ndfp.o): In function `__sfmoreglue':
io/../../../../../gcc-3.2.1/newlib/libc/stdio/findfp.c:63: undefined
reference to `_malloc_r'
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(fo
pen.o): In function `_fopen_r':
io/../../../../../gcc-3.2.1/newlib/libc/stdio/fopen.c:138: undefined
reference to `_open_r'
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(fr
eopen.o): In function `freopen':
io/../../../../../gcc-3.2.1/newlib/libc/stdio/freopen.c:111: undefined
io/../../../../../gcc-3.2.1/newlib/libc/stdio/freopen.c:130: undefined
io/../../../../../gcc-3.2.1/newlib/libc/stdio/freopen.c:133: undefined
io/../../../../../gcc-3.2.1/newlib/libc/stdio/freopen.c:122: undefined
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(fs
eek.o): In function `fseek':
io/../../../../../gcc-3.2.1/newlib/libc/stdio/fseek.c:305: undefined
io/../../../../../gcc-3.2.1/newlib/libc/stdio/fseek.c:310: undefined
reference to `_fstat_r'
io/../../../../../gcc-3.2.1/newlib/libc/stdio/fseek.c:263: undefined
io/../../../../../gcc-3.2.1/newlib/libc/stdio/fseek.c:283: undefined
io/../../../../../gcc-3.2.1/newlib/libc/stdio/fseek.c:207: undefined
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(ma
kebuf.o): In function `__smakebuf':
io/../../../../../gcc-3.2.1/newlib/libc/stdio/makebuf.c:50: undefined
io/../../../../../gcc-3.2.1/newlib/libc/stdio/makebuf.c:81: undefined
io/../../../../../gcc-3.2.1/newlib/libc/stdio/makebuf.c:96: undefined
reference to `isatty'
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(mk
temp.o): In function `_gettemp':
io/../../../../../gcc-3.2.1/newlib/libc/stdio/mktemp.c:114: undefined
reference to `_getpid_r'
io/../../../../../gcc-3.2.1/newlib/libc/stdio/mktemp.c:135: undefined
reference to `_stat_r'
io/../../../../../gcc-3.2.1/newlib/libc/stdio/mktemp.c:151: undefined
io/../../../../../gcc-3.2.1/newlib/libc/stdio/mktemp.c:161: undefined
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(pu
tenv_r.o): In function `_putenv_r':
lib/../../../../../gcc-3.2.1/newlib/libc/stdlib/putenv_r.c:54: undefined
lib/../../../../../gcc-3.2.1/newlib/libc/stdlib/putenv_r.c:48: undefined
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(re
fill.o): In function `__srefill':
io/../../../../../gcc-3.2.1/newlib/libc/stdio/refill.c:78: undefined
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(se
tenv_r.o): In function `_setenv_r':
lib/../../../../../gcc-3.2.1/newlib/libc/stdlib/setenv_r.c:109: undefined
lib/../../../../../gcc-3.2.1/newlib/libc/stdlib/setenv_r.c:85: undefined
reference to `_realloc_r'
lib/../../../../../gcc-3.2.1/newlib/libc/stdlib/setenv_r.c:96: undefined
tvbuf.o): In function `setvbuf':
io/../../../../../gcc-3.2.1/newlib/libc/stdio/setvbuf.c:127: undefined
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(st
dio.o): In function `__sread':
io/../../../../../gcc-3.2.1/newlib/libc/stdio/stdio.c:46: undefined
reference to `_read_r'
dio.o): In function `__swrite':
io/../../../../../gcc-3.2.1/newlib/libc/stdio/stdio.c:83: undefined
reference to `_write_r'
io/../../../../../gcc-3.2.1/newlib/libc/stdio/stdio.c:75: undefined
reference to `_lseek_r'
dio.o): In function `__sseek':
io/../../../../../gcc-3.2.1/newlib/libc/stdio/stdio.c:102: undefined
dio.o): In function `__sclose':
io/../../../../../gcc-3.2.1/newlib/libc/stdio/stdio.c:119: undefined
reference to `_close_r'
rdup_r.o): In function `_strdup_r':
lib/../../../../../gcc-3.2.1/newlib/libc/stdlib/strdup_r.c:11: undefined
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(ti
me.o): In function `time':
/usr/src/redhat/BUILD/i386-rtems-gcc-newlib/build/i386-rtems/newlib/libc/tim
e/../../../../../gcc-3.2.1/newlib/libc/time/time.c:50: undefined reference
to `_gettimeofday_r'
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(tm
pnam.o): In function `worker':
io/../../../../../gcc-3.2.1/newlib/libc/stdio/tmpnam.c:123: undefined
io/../../../../../gcc-3.2.1/newlib/libc/stdio/tmpnam.c:133: undefined
pnam.o): In function `_tmpnam_r':
io/../../../../../gcc-3.2.1/newlib/libc/stdio/tmpnam.c:155: undefined
pnam.o): In function `_tempnam_r':
io/../../../../../gcc-3.2.1/newlib/libc/stdio/tmpnam.c:181: undefined
io/../../../../../gcc-3.2.1/newlib/libc/stdio/tmpnam.c:184: undefined
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(un
getc.o): In function `__submore':
io/../../../../../gcc-3.2.1/newlib/libc/stdio/ungetc.c:58: undefined
io/../../../../../gcc-3.2.1/newlib/libc/stdio/ungetc.c:47: undefined
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(ws
etup.o): In function `__swsetup':
io/../../../../../gcc-3.2.1/newlib/libc/stdio/wsetup.c:50: undefined
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(mp
rec.o): In function `_Balloc':
lib/../../../../../gcc-3.2.1/newlib/libc/stdlib/mprec.c:118: undefined
reference to `_calloc_r'
lib/../../../../../gcc-3.2.1/newlib/libc/stdlib/mprec.c:101: undefined
collect2: ld returned 1 exit status
i386-rtems-gnatmake: *** link failed.
[steved at localhost hello_world_ada]$ cat makelog.txt | more
i386-rtems-gnatbind -x hello.ali
i386-rtems-gnatlink hello.ali
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/bin/ld:
warning:
cannot find entry symbol _start; defaulting to 08048080
b~hello.o: In function `adainit':
b~hello.o(.text+0x41): undefined reference to `__gnat_install_handler'
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/adalib/libgnat.a(s-fileio.o): In
functio
n `system__file_io__delete':
/opt/usr2/usr_src_redhat_BUILD/i386-rtems-gcc-newlib/build/gcc/ada/rts/s-fil
eio.
adb:296: undefined reference to `unlink'
functio
n `system__file_io__finalize__2':
eio.
adb:354: undefined reference to `unlink'
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/adalib/libgnat.a(s-osprim.o): In
functio
n `system__os_primitives__clock':
/opt/usr2/usr_src_redhat_BUILD/i386-rtems-gcc-newlib/build/gcc/ada/rts/s-osp
rim.
adb:83: undefined reference to `gettimeofday'
functio
n `system__os_primitives__timed_delay':
rim.
adb:145: undefined reference to `nanosleep'
I may just need to add some arguments to my gnatmake command.  An example
would be great.
Steve
