rtems-ss-20030128
Francesco Poletti
fpoletti at libero.it
Fri Jan 31 21:39:08 UTC 2003
Hy,now have this error...
May be the Makefile.am of the shmdr directory broken?
Making all in shmdr
gmake[4]: Entering directory
`/home/poletti/buildmulti1/arm-rtems/c/arm_bare_bsp/lib/libbsp/shmdr'
arm-rtems-gcc --pipe -B../../../../../lib/
-B../../../../../arm_bare_bsp/lib/ -specs bsp_specs -qrtems
-DPACKAGE_NAME=\"rtems-c-src-lib-libbsp\"
-DPACKAGE_TARNAME=\"rtems-c-src-lib-libbsp\"
-DPACKAGE_VERSION=\"ss-20030128\"
-DPACKAGE_STRING=\"rtems-c-src-lib-libbsp\ ss-20030128\"
-DPACKAGE_BUGREPORT=\"rtems-bugs at OARcorp.com\" -mcpu=arm7tdmi
-O2 -g -Wall -o o-optimize/addlq.o -c
../../../../../../../rtems-ss-20030128/c/src/lib/libbsp/shmdr/addlq.c
Assembler messages:
FATAL: can't create o-optimize/addlq.o: Not a directory
gmake[4]: *** [o-optimize/addlq.o] Error 2
gmake[4]: Leaving directory
gmake[3]: *** [all-recursive] Error 1
gmake[3]: Leaving directory
`/home/poletti/buildmulti1/arm-rtems/c/arm_bare_bsp/lib/libbsp'
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory
`/home/poletti/buildmulti1/arm-rtems/c/arm_bare_bsp'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/home/poletti/buildmulti1/arm-rtems/c'
make: *** [all-recursive] Error 1
Ralf Corsepius wrote:
> Am Fre, 2003-01-31 um 17.58 schrieb Joel Sherrill:
> > Francesco Poletti wrote:
> > > Yes but my board have yet the shmsupp directory... :-((
> > > My Makefile.am have shmsupp in the SUBDIRS list
> > > and the configure.ac had the shmupp in the Makefile list...
> > > I had run automake and autoconf.
> > > Need I to run also aclocal?
> The nominal sequence is
> aclocal -I <path-to-rtems-toplevel>/aclocal
> automake
> autoconf
> > Run rtems-XXX/bootstrap in your BSP directory.
> Overkill.
> If integrating/adding a BSP you need to run bootstrap once inside of
> c/src/lib/libbsp/<cpu>.
> Then configure a build-tree with maintainer-mode enabled (configure
> --enable-maintainer-mode)
Ralf's right. Once you have all the Makefile.am's in place and are
tinkering with them, use --enable-maintainer-mode and things will get
regenerated without you worrying about it.
> Automake then will take care about dependencies itself and will
invoke
> its underlaying components when needed.
> > Never run the
> > tools by hand. It is too error prone.
> What?
I used a poor choice of words. I just meant that running bootstrap
is easy and a single command. It is not difficult or error prone
to run the real autotool command sequence. The only error that can
happen is a human not doing the commands right. Bootstrap eliminates
that risk.
> Boys, do yourselves a favor:
> Read the fschking manuals: http://sources.redhat.com/autobook
> and the RTEMS FAQ.
Sorry guys. I used a very poor choice of word. I really believe in
automake and autoconf and am glad that RTEMS is using it.
> Ralf
--joel
