TCP/IP for small memory devices
Wed Jul 9 11:27:53 UTC 2003
Derick Hammond wrote:
> Hi Joel, Eric:
> I was perhaps a little misleading in my last post.
> The specifications of the target board are:
>         512KByte EPROM used .text
>         128KByte RAM used for .data .bss and heap
> Does this improve my chances with the RTEMS TCP/IP Stack?
Yes but you will have to be careful about limiting the number of TCP/IP
buffers.
See the Networking Guide and see how if you can build some test based upon
the httpd or ftpd sample that meets your requirements.
> Regards,
> Derick
>>> Hello All:
>>> Is there a document that suggests ways of tailoring the RTEMS
>>> implementation of the TCP/IP stack for small memory foot-prints?
>>> The target board that I am writing my application for has a total of
>>> 128KBytes of RAM, and I would like suggestions on how I can use the
>>> RTEMS TCP/IP stack in this memory foot-print.
>> Is this the total for code, data, bss, heap, etc?  Or do you have
>> some Flash/Rom for code space?
>> The code space for an application with TCP/IP is usually over 128K.
>> I recall 256K being the
>> ballpark number on a 68k.
>>>   Or would it be worthwhile porting TinyIP to RTEMS?
>> Most certainly, yes.  It is designed for lower memory footprints.
>> There are others including http://dunkels.com/adam/uip/.  I don't
>> know which would be the best to
>> port.
>>> Thanks in advance.
>>> Regards,
>>> Derick Hammond
