RTEMS specific in Ada?
Wed Jul 16 18:08:24 UTC 2003
Per Dalgas Jakobsen wrote:
> Hi,
> I have ventured on from the basic hello-world to actually using rtems-specific stuff in my application, but I get:
> ***some rtems directive*** is undefined (more references follow)
> and if I include the "with rtems;" I get: "... file "rtems.ads" not found"
rtems.ads is in cpukit/ada.
> What am I missing here?
> How do I get access to the rtems stuff in an Ada-application?
You have to add --enable-ada to the configure command to get those
installed.
THen you have to make sure your ADA_INCLUDE_PATH points to the right
place.
> Best regards
> Per
