Flash Filesystems
Chris Johns cjohns at cybertec.com.au
Wed Jul 16 23:03:32 UTC 2003
Derick Hammond wrote:
> Hello All:
> I need to implement a file-system on both an Intel StrataFlash device
> and also a SanDisk CompactFlash device.
> I am wondering if there are any good examples of similar implementations
> in the current RTEMS code base.  If there are can someone give me a hint
> to where they are?
> I presume I will be able to use the ATA driver for the CompactFlash
> device.  Has anyone tried this in the past?
We have the DOSFS code working with compact flash cards. The sync system call is
missing and no hot media change support but otherwise all seems fine.
I have ported the disk performance test program to Bonnie and it seems works.
  Chris Johns, cjohns at cybertec.com.au
