Flash Filesystems
Eugeny S. Mints eugeny.mints at auriga.ru
Thu Jul 17 07:57:15 UTC 2003
Hi, all!
On Wed, 16 Jul 2003 20:19:41 -0500, Chris Caudle <chris at chriscaudle.org>
wrote:
> On Wed July 16 2003 6:03 pm, Chris Johns wrote:
>> We have the DOSFS code working with compact flash cards.
> Watch out for sector lifetime when using DOSFS.  The FAT normally goes to
> the same sector, so if you change files a lot (extend, add, delete, etc.)
> you can change the FAT so many times that it wears out.  Usually only a
> problem if you have files into the thousands, but something to consider.
> Typical write lifespan of Flash would be on the order of 100 000, but the
> FAT could be updated multiple times for each file.  One person reported
> problems with flash disk failure after copying on the order of 25 000
> files when using FAT file system.
General solution assumed is the following. You need to configure libblock
in a such way which is the most suitable for you own unique DOSFS
utilization case. Somebody may need speed up, somebody may need robustness.
Currently libblock configuration involves configuration of cache buffers
number and flush task priority. In general it also possible to configure
cache algorithms employed but for now you need to modify libblock source
code for this purpose(unfortunately, libblock version which allows to
configure cache algorithms even "on-the-fly" hasn't finished yet and
postponed:(
But even for now I think it is possible to avoid(or at least to improve)
behaviour you described above by configuration of appropriate cache buffers
number and by coordination of LRU algorithm currently employed in libblock
with user access to files under DOSFS. I mean organization of user access
in a such way that the cache buffer which contains FAT sector will be not
overloaded by other data as long as possible. For this, it is also
important how your files are spaned across the hard disk.( I mean
fragmentation)
Victor, any comments?
Regards,
			Eugeny
