Error while installing binutils gcc gdb RPM's
Aditya
avpenu at essex.ac.uk
Sat Jul 26 15:14:11 UTC 2003
Hi,
In the KDE Terminal when i try to install the RTEMS c/c++ toolset I get
errors as below:
$ rpm -i rtems-base-binutils-2.13.2.1-2.i686.rpm
error: cannot open packages index using db3 - Operation not permitted
(1)
error: cannot open packages database in/var/lib/rpm
May I know what is the cause of this error, Im using linux mandrake 9.1
Aditya
URL: <http://lists.rtems.org/pipermail/users/attachments/20030726/9a15a787/attachment.html>
