How to build Unix BSP ?
Cedric Aubert cedric_aubert at yahoo.fr
Mon Jul 28 11:00:19 UTC 2003
Ok thanks a lot. :-)
I will try today.
> -----Original Message-----
> From: Ralf Corsepius
[mailto:corsepiu at faw.uni-ulm.de]
> Sent: Monday, July 28, 2003 12:37 PM
> To: cedric_aubert at yahoo.fr
> Cc: RTEMS Users
> Subject: RE: How to build Unix BSP ?
> On Mon, 2003-07-28 at 11:13, Cedric Aubert wrote:
> > Ok thanks I will try configure without option.
> > In fact I try with -enable-rtemsbsp=posix and
> > -target=i386-rtems.
> > And doesn't work.
> Yes, this doesn't work, because the posix-BSP is
member of the
> "unix"-CPU-family, not of the i386-CPU-family.
> FYI: The "unix"-CPU family is the "RTEMS-emulation"
ontop of a unix-OS.
> It is supposed to be configured with the target-name
of the OS you want
> to run it ontop off.
> I.e: --target=i386-pc-linux-gnu for linux, or
> --target=sparc-sun-solaris5.7 for Solaris5.7,
> --target=i386-pc-cygwin for Cygwin etc.
> If running configure without "--target", the
configure script with check
> your build-host's system, will implicitly use the
value it detects and
> will build unix/posix for this system.
> So unless you want to cross-build unix/posix (Known
not to work with
> rtems-4.5 and known to be troublesome for some
targets with
> rtems-4.6.x), the defaults are what you want and you
normally don't have
> to specify "--target" for unix/posix.
> Ralf
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
