TCP/IP for small memory devices
Derick Hammond derick at perkinstechnologies.com.au
Wed Jul 9 00:49:41 UTC 2003
Hi Joel, Eric:
I was perhaps a little misleading in my last post.
The specifications of the target board are:
         512KByte EPROM used .text
         128KByte RAM used for .data .bss and heap
Does this improve my chances with the RTEMS TCP/IP Stack?
Regards,
Derick
At 07:31 PM 8/07/2003 -0500, you wrote:
>Derick Hammond wrote:
>>Hello All:
>>Is there a document that suggests ways of tailoring the RTEMS
>>implementation of the TCP/IP stack for small memory foot-prints?
>>The target board that I am writing my application for has a total of
>>128KBytes of RAM, and I would like suggestions on how I can use the RTEMS
>>TCP/IP stack in this memory foot-print.
>Is this the total for code, data, bss, heap, etc?  Or do you have some
>Flash/Rom for code space?
>The code space for an application with TCP/IP is usually over 128K.  I
>recall 256K being the
>ballpark number on a 68k.
>>   Or would it be worthwhile porting TinyIP to RTEMS?
>Most certainly, yes.  It is designed for lower memory footprints.
>There are others including http://dunkels.com/adam/uip/.  I don't know
>which would be the best to
>port.
>>Thanks in advance.
>>Regards,
>>Derick Hammond
