autotool question: script permissions
Till Straumann
strauman at slac.stanford.edu
Tue Jul 15 08:28:07 UTC 2003
Ralf Corsepius wrote:
>On Fri, 2003-07-11 at 19:50, Till Straumann wrote:
>>Hi.
>>I notice that the 'install-if-change' script (in tools/build)
>>which is generated during the build process gets installed without
>>the execution permission bits set. (644 instead of 755)
>> - what needs to be changed to correct that?
>... still investigating ...
>Till, could you please perform this test with the tarball below:
>tar xzvf automake-installtest-0.1.tar.gz
>cd automake-installtest-0.1
>./configure
>make DESTDIR=/tmp install
>find /tmp/usr/local -type f -exec ls -l {} \;
>I am interested in the output of the find.
On my (mandrake 9.1) linux-ppc tibook, I get:
-rwxr-xr-x 1 till till 0 Jul 15 00:58
/tmp/usr/local/bin/myscript
-rw-r--r-- 1 till till 0 Jul 15 00:58
/tmp/usr/local/share/mydata
On my redhat-7.3 machine (linux-i386) at work I get:
-rw-r--r-- 1 till users 0 Jul 15 01:00
-rw-r--r-- 1 till users 0 Jul 14 23:46
On a solaris-8 machine at work:
-rwxr-xr-x 1 strauman qa 0 Jul 15 01:08
-rw-r--r-- 1 strauman qa 0 Jul 15 01:08
Another linux-i386 machine:
-rwxr-xr-x 1 strauman qa 0 Jul 15 01:13
-rw-r--r-- 1 strauman qa 0 Jul 15 01:13
A DEC Tru64 unix (alpha) box:
-rwxr-xr-x 1 strauman system 0 Jul 15 01:16
-rw-r--r-- 1 strauman system 0 Jul 15 01:16
It seems that the second box (which is my main development station)'
"install"
program caused the problem. If I replace it with a different version, I
also
get:
-rwxr-xr-x 1 till users 0 Jul 15 01:19
-rw-r--r-- 1 till users 0 Jul 15 01:19
I 'string'ed the problematic version and found
@(#) OpenAFS stable 1.0.4 built 2001-05-23
(we use AFS a lot here) - apparently 'install' distributed with OpenAFS
1.0.4
is to blame - it got picked up from '/usr/local/bin'.
Sorry for the hassle - was just not easy to track down.
Thanks for your help
-- T.
>Ralf
