DOSFS
Eugeny S. Mints Eugeny.Mints at oktet.ru
Tue Jun 3 13:52:48 UTC 2003
On Tue, 3 Jun 2003, Eric Valette wrote:
> Chris Johns wrote:
> > Is this correct behaviour ? The Single Unix Standard for unlink() states
> > in the error codes:
> >  [EBUSY]
> >     The file named by the path argument cannot be unlinked
> >     because it is being used by the system or another process
> >     and the implementation considers this an error.
> > My reading is an open() then unlink() should fail.
> I disagree : on Unix in general, you can unlink a file even if the
> refcount in non zero. In this case it disappear from the file system
> name space so that no other open can be performed. The file is deleted
> once the refcount drops to zero.
My implementaion bases on this idea and I do think it is
the most approptiate behaviour.
>The EBUSY code is a corner case for
> executable file, as the VM can request pages for running process via
> paging in and may use the path of the executable...
> At least this is my understanding of EBUSY.
Eugeny S. Mints
OKTET Ltd.
1 Ulianovskaya st., Petergof, St.Petersburg, 198904 Russia
Phone: +7(812)428-4384 Fax: +7(812)327-2246
mailto:Eugeny.Mints at oktet.ru
