program
zxj zhou_xingjian at 163.com
Mon Jun 9 03:05:36 UTC 2003
I'm a beginner of using RTEMS to make applications. I wrote an application that followed the RTEMS's sample hello, but when I made it the system told me the file can't be found. If I move all my files into the folder 'hello', it is OK. I don't know which files are relation to my program and whether I should make some declares in some files. BTW, I had used bootstrap and succeeded.
my RTEMS is configured as: ../rtems-4.5.0/configure -target=i386-rtems -disable-posix -disable-tests -enable-rtemsbsp=pc386 -prefix=/opt/rtems
My sample's name is "first".
Altered files:
rtems-4.5.0/c/src/tests/samples/:
1.   makefile.am:
SUBDIRS = hello ticker first base_sp unlimited minimum $(MP_TESTS) \
    $(CPLUSPLUS_TESTS) $(FP_TESTS)
2.   makefile.in:
SUBDIRS = hello ticker first base_sp unlimited minimum $(MP_TESTS)     $(CPLUSPLUS_TESTS) $(FP_TESTS)
3.   configure.in:
AC_OUTPUT(
Makefile
base_sp/Makefile
hello/Makefile
first/Makefile
minimum/Makefile
paranoia/Makefile
ticker/Makefile
unlimited/Makefile
base_mp/Makefile
base_mp/node1/Makefile
base_mp/node2/Makefile
cdtest/Makefile
The following is the error information:
Making all in first
/bin/sh: cd: first: No such file or directory
make[4]: *** [all-recursive] Error 1
make[4]: Leaving directory `/usr/local/source/RTEMS/tools/b-rtems/i386-rtems/c/pc386/tests/samples'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/usr/local/source/RTEMS/tools/b-rtems/i386-rtems/c/pc386/tests'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/usr/local/source/RTEMS/tools/b-rtems/i386-rtems/c/pc386'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/local/source/RTEMS/tools/b-rtems/i386-rtems/c'
make: *** [all-recursive] Error 1
Thanks for your help!
                            shannon
                            6/9/2003
ÅÌÖг¬¼¶Ó¯Àû¾¡ÔÚÕÆÎÕ ÏíÊÜÀ­ÉýµÄ¿ì¸Ð        http://list.163.com/mlist/pzjg/pzjg.htm
°Ù·Ö°ÙÅ®ÓÑ - ´º¼¾Ñ¡ÃÀ»î¶¯!                 http://love.163.com
¸öÈ˿ռäÃâ·ÑÊÔÓà                           http://www.nease.net
