What is RTEMS epoch ?
Dhiraj Gaurh dhiraj at utstar.com
Fri Jun 13 05:27:34 UTC 2003
Hi,
 Thanks for your reply. When you wrote "Note Jan 1, 1970" , did you mean
"NOT Jan 1, 1970" , or did you mean it could also be Jan 1, 1970, if so
configured. Thanks for your patience.
regards
Dhiraj
----- Original Message -----
From: "Paul Whitfield" <paulw at microsol.iinet.net.au>
To: "Dhiraj Gaurh" <dhiraj at utstar.com>
Cc: <rtems-users at oarcorp.com>
Sent: Friday, June 13, 2003 10:37 AM
Subject: Re: What is RTEMS epoch ?
> Dhiraj Gaurh wrote:
> > Hi,
> >  When I try to obtain the time using RTEMS_GET_SECONDS_SINCE_EPOCH, what
> > is the "epoch" that RTEMS uses. When does time start for RTEMS ?
> > regards,
> > Dhiraj
> Epoch is Jan 1,1988
> (Note Jan 1, 1970).
> Regards
> Paul
