rtems_task_wake_after
Fabio Degiovanni - Eicas
degiovanni at eicas.it
Fri Jun 20 10:20:13 UTC 2003
Dear Sirs,
I'm new with RTEMS; I installed it on a Linux RedHat
7.3, my target is SPARC ERC32. I run my application using the ERC32
simulatoror within sparc-rtems-gdb.
I tried with this simple example (see code below). I set up
CONFIGURE_MICROSECONDS_PER_TICK 1000 and I ask
rtems_task_wake_after(10000) whitch for me means that the task should be
blocked for 10s.
I have two problems:
-rtems_task_wake_after instead of waking after 10s wakes after 1s
-after 30 iteration the process doesn't go on; in the debugger I saw
that it is in the funtion _CPU_Thread_Idle_body ()
If I askrtems_task_wake_after(1000) rhe process doesn't freeze, but the
time scale is still wrong.
Can anyone of you help me?
Thank you very much in advance
Fabio Degiovanni
my code:
#include <bsp.h>
rtems_task user_application(rtems_task_argument argument);
rtems_task Init(
rtems_task_argument ignored
rtems_id tid;
rtems_status_code status;
rtems_name name;
name=rtems_build_name('A','P','P','1');
status=rtems_task_create(name,10,RTEMS_MINIMUM_STACK_SIZE,RTEMS_DEFAULT_MODES,RTEMS_DEFAULT_ATTRIBUTES,&tid);
if(status!=RTEMS_SUCCESSFUL){
printf("rtems_task_create failed with status of %d.\n",status);
exit(1);
status=rtems_task_start(tid,user_application,0);
printf("rtems_task_start failed with status of %d.\n",status);
exit(1);
status=rtems_task_delete(RTEMS_SELF);
printf("rtems_task_delete returned with status of %d.\n",status);
exit(1);
rtems_task user_application(rtems_task_argument argument){
rtems_interval inter=10000;
int i=0;
while(1){
printf("user_application %d\n",i);
rtems_task_wake_after(inter);
i++;
if(i==100){
rtems_shutdown_executive(0);
/* configuration information */
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER /*for stdio*/
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER /*for time services*/
#define CONFIGURE_MICROSECONDS_PER_TICK 1000
#define CONFIGURE_MAXIMUM_TASKS 2
#define CONFIGURE_INIT_TASK_NAME rtems_build_name('E','X','A','M')
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#include <confdefs.h>
/* end of file */
my makefile:
# Makefile
# RTEMS_MAKEFILE_PATH is typically set in an environment variable
EXEC=hello.exe
PGM=${ARCH}/$(EXEC)
# optional managers required
MANAGERS=io
# C source names
CSRCS = test.c
COBJS_ = $(CSRCS:.c=.o)
COBJS = $(COBJS_:%=${ARCH}/%)
# C++ source names
CXXSRCS =
CXXOBJS_ = $(CXXSRCS:.cc=.o)
CXXOBJS = $(CXXOBJS_:%=${ARCH}/%)
# AS source names
ASSRCS =
ASOBJS_ = $(ASSRCS:.s=.o)
ASOBJS = $(ASOBJS_:%=${ARCH}/%)
# Libraries
LIBS = -lrtemsall -lc
include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
include $(RTEMS_CUSTOM)
include $(PROJECT_ROOT)/make/leaf.cfg
OBJS= $(COBJS) $(CXXOBJS) $(ASOBJS)
all: ${ARCH} $(PGM)
$(PGM): $(OBJS)
$(make-exe)
Dott. Ing. Degiovanni Fabio
Eicas Automazione
Via Vincenzo Vela, 27 10128 Torino (ITALIA)
Telefoni +39-11-562.37.98/562.3088 Fax +39-11-436.06.79
