rtems_wake_after
Fabio Degiovanni - Eicas degiovanni at eicas.it
Fri Jun 20 14:34:47 UTC 2003
Dear Jarry Needell,
                                I think you were right: it is a problem
of overflow. I tried with CONFIGURE_MICROSECONDS_PER_TICK 1000 and
rtems_task_wake_after(1000). The problems is at the 305th iteration. I
tried to put the directive rtems_clock_get(
RTEMS_CLOCK_GET_TICKS_SINCE_BOOT, &inter ); to see at what time (in
ticks this happens) and I found out at 305266 ticks.
I don't understand what variables is subjected to overflow. I'm used to
Linux real-time: in that case there is a periodic interrupt timer that
is loaded to the value of MICROSECONDS_PER_TICK 1000, it counts down
till 0 then it gives an interrupt, the interrupt service routine
increment the value of ticks an reset the PIT to the
MICROSECONDS_PER_TICK value. If RTEMS follows nearly the same procedure
I don't see any point in which an overflow can occur. How does RTEMS
work? What the variable that is subject to overflow? Why?
Thank you very much for your help
Fabio Degiovanni
Dott. Ing. Degiovanni Fabio
Eicas Automazione
Via Vincenzo Vela, 27 10128 Torino (ITALIA)
Telefoni +39-11-562.37.98/562.3088 Fax +39-11-436.06.79
