make fileio example???
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Fri Jun 6 14:12:55 UTC 2003
Hello David,
it seems, the files "ata.h" and "fsmount.h" are not, where
they should be. There was a problem I think that these files
have not been installed during "make install". As a
workaround, if you copy these files to your project,
everything should be fine.
Ralf, can you have a look at these two files (and the
appropriate auto* files)?
wkr,
Thomas.
> hello all:
> I want to make fileio example.
> I have build and install rtems-4.6.0pre3 successfully,
> and then copy fileio source code files to
> test/samples/fileio.
> when make,i got errors as below:
> administratorrtems at RTEMS
> ~/rtems-4.6.0pre3/c/src/tests/samples/fileioexampl
> $ make
> i386-rtems-gcc --pipe
> -B/opt/rtems-4.6.0pre3/i386-rtems/pc386/lib/ -specs b
> ll -O4 -g -c -o o-optimize/init.o init.c
> In file included from init.c:24:
> system.h:30:54: rtems/ata.h: No such file or directory
> system.h:49: `ATA_DRIVER_TABLE_ENTRY' undeclared here
> (not in a function)
> system.h:49: initializer element is not constant
> system.h:49: (near initialization for
> `Device_drivers[3]')
> init.c:37:27: rtems/fsmount.h: No such file or
> directory
> init.c:44: parse error before "fs_table"
> init.c:44: warning: type defaults to `int' in
> declaration of `fs_table'
> init.c:45: warning: braces around scalar initializer
> init.c:45: warning: (near initialization for
> `fs_table[0]')
> init.c:46: warning: initialization makes integer from
> pointer without a cas
> init.c:46: warning: excess elements in scalar
> initializer
> init.c:46: warning: (near initialization for
> `fs_table[0]')
> init.c:47: warning: excess elements in scalar
> initializer
> init.c:47: warning: (near initialization for
> `fs_table[0]')
> initializer
> `fs_table[0]')
> init.c:48: `FSMOUNT_MNT_OK' undeclared here (not in a
> function)
> init.c:48: `FSMOUNT_MNTPNT_CRTERR' undeclared here
> (not in a function)
> init.c:48: `FSMOUNT_MNT_FAILED' undeclared here (not
> in a function)
> init.c:48: warning: excess elements in scalar
> initializer
> init.c:48: warning: (near initialization for
> `fs_table[0]')
> init.c:50: warning: excess elements in scalar
> initializer
> init.c:50: warning: (near initialization for
> `fs_table[0]')
> init.c:51: warning: braces around scalar initializer
> init.c:51: warning: (near initialization for
> `fs_table[1]')
> init.c:52: warning: initialization makes integer from
> init.c:52: warning: excess elements in scalar
> initializer
> init.c:52: warning: (near initialization for
> `fs_table[1]')
> init.c:53: warning: excess elements in scalar
> initializer
> init.c:53: warning: (near initialization for
> `fs_table[1]')
> initializer
> `fs_table[1]')
> init.c:54: `FSMOUNT_MNT_OK' undeclared here (not in a
> function)
> init.c:54: `FSMOUNT_MNTPNT_CRTERR' undeclared here
> (not in a function)
> init.c:54: `FSMOUNT_MNT_FAILED' undeclared here (not
> in a function)
> init.c:54: warning: excess elements in scalar
> initializer
> init.c:54: warning: (near initialization for
> `fs_table[1]')
> init.c:56: warning: excess elements in scalar
> initializer
> init.c:56: warning: (near initialization for
> `fs_table[1]')
> init.c:57: warning: braces around scalar initializer
> init.c:57: warning: (near initialization for
> `fs_table[2]')
> init.c:58: warning: initialization makes integer from
> init.c:58: warning: excess elements in scalar
> initializer
> init.c:58: warning: (near initialization for
> `fs_table[2]')
> init.c:59: warning: excess elements in scalar
> initializer
> init.c:59: warning: (near initialization for
> `fs_table[2]')
> initializer
> `fs_table[2]')
> init.c:60: `FSMOUNT_MNT_OK' undeclared here (not in a
> function)
> init.c:60: `FSMOUNT_MNTPNT_CRTERR' undeclared here
> (not in a function)
> init.c:60: `FSMOUNT_MNT_FAILED' undeclared here (not
> in a function)
> init.c:60: warning: excess elements in scalar
> initializer
> init.c:60: warning: (near initialization for
> `fs_table[2]')
> init.c:62: warning: excess elements in scalar
> initializer
> init.c:62: warning: (near initialization for
> `fs_table[2]')
> init.c:63: warning: braces around scalar initializer
> init.c:63: warning: (near initialization for
> `fs_table[3]')
> init.c:64: warning: initialization makes integer from
> init.c:64: warning: excess elements in scalar
> initializer
> init.c:64: warning: (near initialization for
> `fs_table[3]')
> init.c:65: warning: excess elements in scalar
> initializer
> init.c:65: warning: (near initialization for
> `fs_table[3]')
> initializer
> `fs_table[3]')
> init.c:66: `FSMOUNT_MNT_OK' undeclared here (not in a
> function)
> init.c:66: `FSMOUNT_MNTPNT_CRTERR' undeclared here
> (not in a function)
> init.c:66: `FSMOUNT_MNT_FAILED' undeclared here (not
> in a function)
> init.c:66: warning: excess elements in scalar
> initializer
> init.c:66: warning: (near initialization for
> `fs_table[3]')
> init.c:68: warning: excess elements in scalar
> initializer
> init.c:68: warning: (near initialization for
> `fs_table[3]')
> init.c:69: warning: braces around scalar initializer
> init.c:69: warning: (near initialization for
> `fs_table[4]')
> init.c:70: warning: initialization makes integer from
> init.c:70: warning: excess elements in scalar
> initializer
> init.c:70: warning: (near initialization for
> `fs_table[4]')
> init.c:71: warning: excess elements in scalar
> initializer
> init.c:71: warning: (near initialization for
> `fs_table[4]')
> initializer
> `fs_table[4]')
> init.c:72: `FSMOUNT_MNT_OK' undeclared here (not in a
> function)
> init.c:72: `FSMOUNT_MNTPNT_CRTERR' undeclared here
> (not in a function)
> init.c:72: `FSMOUNT_MNT_FAILED' undeclared here (not
> in a function)
> init.c:72: warning: excess elements in scalar
> initializer
> init.c:72: warning: (near initialization for
> `fs_table[4]')
> init.c:74: warning: excess elements in scalar
> initializer
> init.c:74: warning: (near initialization for
> `fs_table[4]')
> init.c:75: warning: braces around scalar initializer
> init.c:75: warning: (near initialization for
> `fs_table[5]')
> init.c:76: warning: initialization makes integer from
> init.c:76: warning: excess elements in scalar
> initializer
> init.c:76: warning: (near initialization for
> `fs_table[5]')
> init.c:77: warning: excess elements in scalar
> initializer
> init.c:77: warning: (near initialization for
> `fs_table[5]')
> initializer
> `fs_table[5]')
> init.c:78: `FSMOUNT_MNT_OK' undeclared here (not in a
> function)
> init.c:78: `FSMOUNT_MNTPNT_CRTERR' undeclared here
> (not in a function)
> init.c:78: `FSMOUNT_MNT_FAILED' undeclared here (not
> in a function)
> init.c:78: warning: excess elements in scalar
> initializer
> init.c:78: warning: (near initialization for
> `fs_table[5]')
> init.c:80: warning: excess elements in scalar
> initializer
> init.c:80: warning: (near initialization for
> `fs_table[5]')
> init.c:81: warning: braces around scalar initializer
> init.c:81: warning: (near initialization for
> `fs_table[6]')
> init.c:82: warning: initialization makes integer from
> init.c:82: warning: excess elements in scalar
> initializer
> init.c:82: warning: (near initialization for
> `fs_table[6]')
> init.c:83: warning: excess elements in scalar
> initializer
> init.c:83: warning: (near initialization for
> `fs_table[6]')
> initializer
> `fs_table[6]')
> init.c:84: `FSMOUNT_MNT_OK' undeclared here (not in a
> function)
> init.c:84: `FSMOUNT_MNTPNT_CRTERR' undeclared here
> (not in a function)
> init.c:84: `FSMOUNT_MNT_FAILED' undeclared here (not
> in a function)
> init.c:84: warning: excess elements in scalar
> initializer
> init.c:84: warning: (near initialization for
> `fs_table[6]')
> init.c:86: warning: excess elements in scalar
> initializer
> init.c:86: warning: (near initialization for
> `fs_table[6]')
> init.c:87: warning: braces around scalar initializer
> init.c:87: warning: (near initialization for
> `fs_table[7]')
> init.c:88: warning: initialization makes integer from
> init.c:88: warning: excess elements in scalar
> initializer
> init.c:88: warning: (near initialization for
> `fs_table[7]')
> init.c:89: warning: excess elements in scalar
> initializer
> init.c:89: warning: (near initialization for
> `fs_table[7]')
> initializer
> `fs_table[7]')
> init.c:90: `FSMOUNT_MNT_OK' undeclared here (not in a
> function)
> init.c:90: `FSMOUNT_MNTPNT_CRTERR' undeclared here
> (not in a function)
> init.c:90: `FSMOUNT_MNT_FAILED' undeclared here (not
> in a function)
> init.c:90: warning: excess elements in scalar
> initializer
> init.c:90: warning: (near initialization for
> `fs_table[7]')
> init.c:92: warning: excess elements in scalar
> initializer
> init.c:92: warning: (near initialization for
> `fs_table[7]')
> init.c:93: warning: data definition has no type or
> storage class
> init.c: In function `fileio_fsmount':
> init.c:157: warning: implicit declaration of function
> `rtems_fsmount'
> make: *** [o-optimize/init.o] Error 1
> later ,i patch pr369_fileio_sample_fsmount.diff,but i
> got some Hunk FAILED...
> how can i get fileio example running?
> Thanks !
> David wu
> _________________________________________________________
> Do You Yahoo!?
> Á÷Á¬ÍøÂçÊÀ½çµÄ¡°Ä㡱ÊÇË£¿
> http://cn.rd.yahoo.com/mail_cn/tag/?http://cn.surveys.yahoo.com/cn_user_profile_study_may2003
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-
systems.de/pgp_keys.htm
