multiprocessing
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Jun 10 17:22:41 UTC 2003
ktari jalel wrote:
> hi
> thinks
> i can't undersand how to fixe the task to the processor that i like
> because my tasks will run in 2 leon'processor
> so i need to give to every processor somes tasks that i choose
The mptests include some examples where the executable is the same on
both CPUs (except for the setting of the node number) and the
application
startup decides which tasks to start based upon the CPU number.
If your hardware solution gives each CPU a register to read to determine
which CPU it is, then the BSP can fill in the node number. I think the
unix/posix BSP uses this to grab it from an environment variable.
> regards
> Do You Yahoo!? -- Une adresse @yahoo.fr gratuite et en français !
> Testez le nouveau Yahoo! Mail
joel at OARcorp.com On-Line Applications Research
