RTEMS and Motorola 68000
Cedric Aubert
cedric_aubert at yahoo.fr
Mon Jun 30 06:54:29 UTC 2003
Hi,
Thanks, You are write, I am trying to find efi68k and
I found that.
So it seems to be ok.
Thanks for your help.
CPU CPU
LANGUAGE FAMILY MODEL TARGET
SUITES
C a29k a29205 portsw
(note 2)
C m68k m68000 efi68k
(note 1)
C m68k m68020 DY-4 DMV152
(note 1)
C m68k m68020 Motorola MVME136
(note 5)
C m68k m68030 Motorola MVME147
(note 1)
C m68k m68030 Motorola MVME147s
(note 1)
C m68k m68lc040 Motorola MVME162
(note 1)
C m68k m68ec040 Motorola IDP
(note 1)
C m68k m68302 generic 68302
(note 1)
C m68k m68302 generic 68360
(note 1)
C m68k m68332 efi332
(note 1)
C i386 i386_fp Force CPU-386 ALL
TESTS
C i386 i486 DJGPP/PC-AT ALL
TESTS
C i386 pentium DJGPP/PC-AT ALL
TESTS
C i960 i960ca Cyclone CVME961
(note 5)
C hppa hppa7100 simhppa
(note 1)
C mips64 r4600 p4000
(note 1)
C mips64 r4650 p4000
(note 1)
C ppc 403 Papyrus
(note 1)
C sparc erc32 sis
(note 4)
C UNIX NA Solaris 2 (SPARC) ALL
TESTS (inlines)
TESTS (macros)
C UNIX NA Linux (i386) NOT
TESTED
C UNIX NA HPUX (PA-RISC)
(note 2)
C no_cpu NA no_bsp
(note 3)
NOTES:
(1) Target board is not owned by RTEMS Project. The
target is known
to compile and link with all appropriate tests
successfully.
If the target does not support multiprocessor
configurations, then
"ALL TESTS" does not include the multiprocessor
tests.
(2) RTEMS Project cannot internally compile or test
this target.
(3) Target is not intended to be executed. It is only
an example.
(4) sis is the SPARC Instruction Simulator. It is
available from
ftp.estec.esa.nl in the /pub/ws/wsd/erc32 directory.
Cedric
> -----Original Message-----
> From: Thomas Doerfler
[mailto:Thomas.Doerfler at imd-systems.de]
> Sent: Friday, June 27, 2003 10:47 PM
> To: cedric_aubert at yahoo.fr
> Subject: Re: RTEMS and Motorola 68000
> Hi,
> the "efi68k" BSP also seems to be for a M68(HC)000
> cpu,, so this might be quite close to your
> configuration.
> wkr,
> Thomas.
> > Hi,
> > I am new to the list and to rtems to.
> > I want to known if RTEMS have support
> > for motorola 68000 processors.
> > I have found that it's should work with
> > 68k processor, but I found on the documentation
> > that it's ok for 68xxx and 683xx but it's write
> > like 68020. But I use a real 68000 the first of
> > motorola (at 16Mhz), not the 32 bits adress bus
> > processors.
> > The 68K, I use it's the adress bus had 22 bits.
> > Of course without MMU.
> > Is RTEMS support the first mc68000 processor ?
> > Sorry if my question is stupid but many system
> > support 32bits 68k but not the 22bits 68k (ucLinux
for
> > example, if I don't lose my mind :-).
> > Thanks a lot
> > AUBERT Cedric
> > SDEL Controle Commande
> > Service R&D
> > rue Nungesser & Coli
> > 44860 St Aignan de Grand Lieu
> > Tel : +33 (0)2 40 84 50 00
> > Poste : 5109
> > Fax : +33 (0)2 40 84 51 10
> > E-mail : cedric_aubert at yahoo.fr
> > Web : http://www.controle-commande.sdel.fr
> > __________________________________
> > Do you Yahoo!?
> > SBC Yahoo! DSL - Now only $29.95 per month!
> > http://sbc.yahoo.com
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler Herbststrasse 8
> D-82178 Puchheim Germany
> email: Thomas.Doerfler at imd-systems.de
> PGP public key available at: http://www.imd-
> systems.de/pgp_keys.htm
Do you Yahoo!?
