Object name recycling problem
Nigel Spon
nigel at adi.co.nz
Mon Mar 3 00:32:09 UTC 2003
Hi,
I seem to have run across a problem with the way object names are
allocated in RTEMS. I have found that a crash I was getting after
making and deleting several tasks was due to the "name" field of the
"Objects_control" structure returned by _Objects_Allocate being nil.
This turns out to be because deleted objects are recycled into the
Inactive chain of the objects_information block, but if _Objects_Close
has been called on them the "name" fields of the freed objects have
been set to nil. When _Objects_Allocate gets around to reallocating a
previously Closed object, Objects_Open calls _Objects_Copy_Name_Raw
with a nil destination pointer... and dies for writing to NIL.
Is this a known problem? (I am using a June 2002 snapshot, but the same
code seems to be in the Feb 2003 snapshot) I can't see what I might be
doing wrong that would cause this behaviour but if this is my fault
somehow I would really like to know...
“Some will say that they were at one time troubled in sleeping but have
“recovered” from it, as though awareness were a disease, as perhaps it
is.”
Nigel Spon
ADInstruments Ltd, Dunedin, NZ
