bdm patch for gdb 5.2?
Erwin Rol
erwin at muffin.org
Thu Mar 6 23:56:05 UTC 2003
I am currently working on a libmpc8xx which is a library derived from
the MPCBDM "patch" for GDB. With that library i (almost) have a patch
for GDB 5.3 ( it should not be too hard to generate a patch for 5.2,
since most stuff is in a new file).
So if you mean the MPC8xx BDM and you can wait until somewhere next week
i can give you what i have, if you mean some other BDM than i can not
help you, sorry.
- Erwin
On Fri, 2003-03-07 at 00:32, Wendell Thompson wrote:
> I see in the maillist archive that a bdm patch for gdb 5.2 was
> discussed. Did anyone ever generate that?
> I need it for the dreaded dwarf errors with gcc 3.2.1 and gdb 5.0.
Dipl.-Ing. Erwin Rol - Software Engineering
tel: +49-(0)8024-479377 gsm: +49-(0)171-6929198 fax: +49-(0)8024-479379
email: erwin at muffin.org
Type: application/pgp-signature
Desc: This is a digitally signed message part
URL: <http://lists.rtems.org/pipermail/users/attachments/20030307/16cf8309/attachment.bin>
