bdm patch for gdb 5.2?
Fri Mar 7 13:53:01 UTC 2003
Erwin Rol wrote:
> I am currently working on a libmpc8xx which is a library derived from
> the MPCBDM "patch" for GDB. With that library i (almost) have a patch
> for GDB 5.3 ( it should not be too hard to generate a patch for 5.2,
> since most stuff is in a new file).
> So if you mean the MPC8xx BDM and you can wait until somewhere next week
> i can give you what i have, if you mean some other BDM than i can not
> help you, sorry.
Unless someone has a great need for gdb 5.2 and not 5.3, I would prefer
to just update the RTEMS toolset to gdb 5.3.  If you look at the RTEMS
patches, they are divided into 3 subparts only two of which are
currently
applied.  The 1st two parts usually update pretty easily.  gcc and
newlib activity has just pushed gdb into the background.
> - Erwin
> On Fri, 2003-03-07 at 00:32, Wendell Thompson wrote:
> > I see in the maillist archive that a bdm patch for gdb 5.2 was
> > discussed. Did anyone ever generate that?
> > I need it for the dreaded dwarf errors with gcc 3.2.1 and gdb 5.0.
>               Dipl.-Ing. Erwin Rol - Software Engineering
> tel: +49-(0)8024-479377  gsm: +49-(0)171-6929198 fax: +49-(0)8024-479379
>                         email: erwin at muffin.org
>    signature.asc       Type: application/pgp-signature
>                 Description: This is a digitally signed message part
