bdm patch for gdb 5.2?
Fri Mar 7 13:54:20 UTC 2003
Erwin Rol wrote:
> On Fri, 2003-03-07 at 01:26, Wendell Thompson wrote:
> > Erwin Rol wrote:
> > > I am currently working on a libmpc8xx which is a library derived from
> > > the MPCBDM "patch" for GDB. With that library i (almost) have a patch
> > > for GDB 5.3 ( it should not be too hard to generate a patch for 5.2,
> > > since most stuff is in a new file).
> > > So if you mean the MPC8xx BDM and you can wait until somewhere next week
> > > i can give you what i have, if you mean some other BDM than i can not
> > > help you, sorry.
> > Thanks, Erwin, but I'm looking for the m68k Coldfire version.
> > I have, however, used a derivative of Sergei Drazhnikov's PPC BDM code
> > on another project. I'd like to see info on your version when you get it
> > done.
> Even though it is not helping you much, other ppl might be interested to
> hear this.
> The MPCBDm is based on that , in both hardware and software, the base i
> used is the 1.2.3 version of Frank Przybylski (which i copied this mail
> so he knows what i am doing :-) The Hardware i have is basically his
> Version 1 Adapter, the software i split up in a general MPC8XX BDM
> library and a GDB patch. The MPC8XX library can also be used to write
> other applications like for example a flash writer or an automated board
> test application.
> Expect the first release somewhere next week.
Since the RTEMS gdb is already set up for multiple patches, I would have
no opposition to including BDM support in the future RTEMS gdb binaries
if it makes sense.
> - Erwin
> > WT
>               Dipl.-Ing. Erwin Rol - Software Engineering
> tel: +49-(0)8024-479377  gsm: +49-(0)171-6929198 fax: +49-(0)8024-479379
>                         email: erwin at muffin.org
>    signature.asc       Type: application/pgp-signature
>                 Description: This is a digitally signed message part
