m68k BDM patch for gdb 5.3
Likely, Grant Grant.Likely at gdcanada.com
Mon Mar 10 21:46:29 UTC 2003
Note about this patch: it is based on the patch included with the BDM
library, not the newer 5.2.1 patch.  I didn't know about the newer patch
until today.
Cheers,
g.
-----Original Message-----
From: Likely, Grant [mailto:Grant.Likely at gdcanada.com]
Sent: Monday, March 10, 2003 2:24 PM
To: 'rtems-users at oarcorp.com'
Subject: m68k BDM patch for gdb 5.3
I noticed that someone was looking for this.  I ported the patch shipped
with the Cybertec BDM library to GDB 5.3 and am using it for my 5407 target
with a P&E wiggler.
Cheers,
g.
diff -urN gdb-5.3/gdb/Makefile.in gdb-5.3-cfbdm/gdb/Makefile.in
--- gdb-5.3/gdb/Makefile.in	2002-11-25 15:05:38.000000000 -0700
+++ gdb-5.3-cfbdm/gdb/Makefile.in	2003-03-05 13:48:08.000000000 -0700
@@ -1386,7 +1386,7 @@
 	sparc-tdep.c sparcl-tdep.c sun3-nat.c \
 	symm-tdep.c symm-nat.c \
 	vax-tdep.c \
-	vx-share/xdr_ld.c vx-share/xdr_ptrace.c vx-share/xdr_rdb.c \
+	vx-share/xdr_ld.c vx-share/xdr_ptrace.c vx-share/xdr_rdb.c
remote-m68k-bdm.c \
 	win32-nat.c \
 	xcoffread.c xcoffsolib.c \
 	xstormy16-tdep.c \
@@ -2012,6 +2012,8 @@
 remote-mips.o: remote-mips.c $(defs_h) $(inferior_h) $(bfd_h) $(symfile_h)
 	$(gdbcmd_h) $(gdbcore_h) $(serial_h) $(target_h) $(remote_utils_h) \
 	$(gdb_string_h) $(gdb_stat_h) $(regcache_h)
+remote-m68k-bdm.o: remote-m68k-bdm.c $(bfd_h) $(wait_h) $(defs_h) \
+        $(inferior_h) $(gdbcore_h) target.h
 # OBSOLETE remote-nindy.o: remote-nindy.c
 # OBSOLETE remote-nrom.o: remote-nrom.c
 # OBSOLETE remote-os9k.o: remote-os9k.c
diff -urN gdb-5.3/gdb/config/m68k/bdm.mt
gdb-5.3-cfbdm/gdb/config/m68k/bdm.mt
--- gdb-5.3/gdb/config/m68k/bdm.mt	1969-12-31 17:00:00.000000000 -0700
+++ gdb-5.3-cfbdm/gdb/config/m68k/bdm.mt	2003-03-05
13:46:01.000000000 -0700
@@ -0,0 +1,5 @@
+# Target: m68k bdm interface for the CPU32 and Coldfire processors.
+TM_CLIBS= -lBDM
+TDEPFILES= m68k-tdep.o remote-m68k-bdm.o
+TM_FILE= tm-bdm.h
diff -urN gdb-5.3/gdb/config/m68k/tm-bdm.h
gdb-5.3-cfbdm/gdb/config/m68k/tm-bdm.h
--- gdb-5.3/gdb/config/m68k/tm-bdm.h	1969-12-31 17:00:00.000000000 -0700
+++ gdb-5.3-cfbdm/gdb/config/m68k/tm-bdm.h	2003-03-05
@@ -0,0 +1,120 @@
+ * Target machine description for Coldfire BDM (Moto 5200)
+ * Copyright (C) 1995  W. Eric Norum
+ * Copyright (C) 1998  Chris Johns (ccj at acm.org)
+ * Based on:
+ *  1. `A Background Debug Mode Driver Package for Motorola's
+ *     16- and 32-Bit Microcontrollers', Scott Howard, Motorola
+ *     Canada, 1993.
+ *  2. `Linux device driver for public domain BDM Interface',
+ *     M. Schraut, Technische Universitaet Muenchen, Lehrstuhl
+ *     fuer Prozessrechner, 1995.
+ *  3. BDM support for gdb by W. Eric Norum
+ *     Saskatchewan Accelerator Laboratory
+ *     University of Saskatchewan
+ *     107 North Road
+ *     Saskatoon, Saskatchewan, CANADA
+ *     S7N 5C6
+ * This file is part of GDB.
+ * This program is free software; you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation; either version 2 of the License, or
+ * (at your option) any later version.
+ * This program is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with this program; if not, write to the Free Software
+ * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
+ * Coldfire does it for us if we use PCC to get the PC
+#define	DECR_PC_AFTER_BREAK	0
+ * We have to control this directly as the CPU32 and Coldfire have
different
+ * breakpoint opcodes.
+#define BREAKPOINT_FROM_PC m68k_bdm_breakpoint_from_pc
+ * Include the generic stuff
+#include "m68k/tm-m68k.h"
+ * Override some of the generic definitions
+ * For uCLinux we need to detect we have a subroutine call
+ * which is really a trap #0. This should be caught by the
+ * the IN_SIGTRAMP handler defined above, but incase it is
+ * not we should try and catch it here.
+extern CORE_ADDR m68k_bdm_saved_pc_after_call PARAMS ((struct frame_info
+#undef SAVED_PC_AFTER_CALL
+#define SAVED_PC_AFTER_CALL(frame) \
+  m68k_bdm_saved_pc_after_call (frame)
+ * we need 40 registers for the CPU32 and Coldfire:
+ *   8 data registers
+ *   8 address registers
+ *   2 other registers (PC, PS)
+ *  22 special registers (actual set depends on architecture)
+ *   0 floating point registers
+#undef NUM_REGS
+#undef REGISTER_BYTES
+#define NUM_REGS    40
+#define REGISTER_BYTES (16*4 + 2*4 + 22*4)
+#undef REGISTER_NAMES
+#define REGISTER_NAME(i) bdm_register_name(i)
+extern const char *bdm_register_name(int i);
+#undef FP0_REGNUM
+#undef FPC_REGNUM
+#undef FPS_REGNUM
+#undef FPI_REGNUM
+#define FP0_REGNUM 40                   /* Floating point register 0 */
+#define FPC_REGNUM FP0_REGNUM + 8       /* 68881 control register */
+#define FPS_REGNUM FPC_REGNUM + 1       /* 68881 status register */
+#define FPI_REGNUM FPS_REGNUM + 1       /* 68881 iaddr register */
+ * The other definitions and macros don't need to be changed:
+ *    a) The Coldfire has no floating point registers
+ *    b) The REGISTER_BYTES_OK macro isn't used
+#define TARGET_HAS_HARDWARE_WATCHPOINTS
+/* We need to remove watchpoints when stepping, else we hit them again! */
+#define HAVE_NONSTEPPABLE_WATCHPOINT
+#define STOPPED_BY_WATCHPOINT(w) cf_stopped_by_watchpoint ()
+/* Use these macros for watchpoint insertion/deletion.  */
+/* type can be 0: write watch, 1: read watch, 2: access watch (read/write)
+#define TARGET_CAN_USE_HARDWARE_WATCHPOINT(type, cnt, ot) \
+		cf_can_use_watchpoint (type, cnt, ot)
+#define target_insert_watchpoint(addr, len, type) cf_insert_watchpoint
(addr, len, type)
+#define target_remove_watchpoint(addr, len, type) cf_remove_watchpoint
(addr, len, type)
+#define target_insert_hw_breakpoint(addr, shadow) cf_insert_hw_breakpoint
(addr, shadow)
+#define target_remove_hw_breakpoint(addr, shadow) cf_remove_hw_breakpoint
(addr, shadow)
+#define target_stopped_data_address() cf_stopped_data_address ()
diff -urN gdb-5.3/gdb/configure.tgt gdb-5.3-cfbdm/gdb/configure.tgt
--- gdb-5.3/gdb/configure.tgt	2002-10-20 06:14:39.000000000 -0600
+++ gdb-5.3-cfbdm/gdb/configure.tgt	2003-03-05 13:46:01.000000000 -0700
@@ -150,6 +150,7 @@
 m68*-motorola-*)	gdb_target=delta68 ;;
 m68*-netx-*)		gdb_target=vxworks68 ;;
 m68*-tandem-*)		gdb_target=st2000 ;;
+m68*-bdm-*)		gdb_target=bdm ;;
 m68*-*-aout*)		gdb_target=monitor ;;
 m68*-*-coff*)		gdb_target=monitor ;;
 m68*-*-elf*)		gdb_target=monitor ;;
diff -urN gdb-5.3/gdb/doc/gdb.texinfo gdb-5.3-cfbdm/gdb/doc/gdb.texinfo
--- gdb-5.3/gdb/doc/gdb.texinfo	2002-09-26 18:21:38.000000000 -0600
+++ gdb-5.3-cfbdm/gdb/doc/gdb.texinfo	2003-03-05 14:15:51.000000000 -0700
@@ -11326,6 +11326,7 @@
 * i960::                        Intel i960
 * M32R/D::                      Mitsubishi M32R/D
 * M68K::                        Motorola M68K
+* Motorola BDM::                Motorola M68K/Coldfire Background Debug
Mode
 @c OBSOLETE * M88K::                        Motorola M88K
 * MIPS Embedded::               MIPS Embedded
 * PA::                          HP PA Embedded
@@ -11722,6 +11723,10 @@
 @item target abug @var{dev}
 ABug ROM monitor for M68K.
+ at kindex target bdm
+Background Debug Mode interface to Motorola 68k/Coldfire machine.
+ at xref{Motorola BDM, , at value{GDBN} and Motorola 68k/Coldfire BDM}.
 @kindex target cpu32bug
 @item target cpu32bug @var{dev}
 CPU32BUG monitor, running on a CPU32 (M68K) board.
@@ -11761,6 +11766,100 @@
 @end table
+ at node Motorola BDM
+ at subsection @value{GDBN} and Motorola BDM
+ at cindex BDM
+ at cindex CPU32
+ at cindex Coldfire
+Background Debug Mode (@dfn{BDM}) provides a full set of debug options
+including the ability to:
+ at itemize @bullet
+ at item Insert breakpoints
+ at item Single-step
+ at item Display register contents
+ at item Display memory contents
+ at item Modify register contents
+ at item Modify memory contents
+ at end itemize
+A small interface circuit connects the BDM interface port on the
+target machine to a parallel printer port on the debugging host.
+A target system can be configured and a program downloaded and
+executed with no bootstrap memory on the target machine and no other
+connection between the debugging host and the target machine.
+The @code{target} command tells @value{GDBN}
+to debug a program running on a target machine
+ at xref{Target Commands, ,Commands for managing targets}.
+For example, the following command tells @value{GDBN} to use a BDM
+interface connected to a ColdFire processor and the @code{LPT0} parallel
port:
+ at example
+target bdm /dev/bdmcf0
+ at end example
+Do not attempt to use the parallel port for any other purpose while
+ at value{GDBN} is using it to control a BDM target.
+Once the BDM target has been selected a few other commands become
+available:
+ at table @code
+ at item bdm_reset
+ at kindex bdm_reset
+Reset the target machine and enable BDM operation in the target.
+ at item bdm_restart
+ at kindex bdm_restart
+Reset the target machine and disable BDM operation in the target.
+This command is useful only if the target machine has some kind of
+bootstrap memory installed.
+ at item bdm_status
+ at kindex bdm_status
+Print the status of the target machine and the BDM interface.
+ at item bdm_setdelay @var{N}
+ at kindex bdm_setdelay
+Some BDM interface circuits can not handle high-speed data transfer.
+This command lets you insert a delay between each BDM clock.
+The larger the value of @var{N}, the longer the delay.
+On most machines the default delay of @var{0} should work just fine.
+ at item bdm_setdebug @var{N}
+ at kindex bdm_setdebug
+Setting the level (@var{N}) to a non-zero value turns on
+debugging messages in the BDM support library.
+ at item bdm_setdriverdebug @var{N}
+ at kindex bdm_setdriverdebug
+debugging messages in the BDM device driver.
+ at end table
+The registers which can be displayed and modified are:
+ at item The data registers: @code{$d0}- at code{$d7}
+ at item The address registers: @code{$a0}- at code{$a5}, @code{$fp}, @code{$sp}
+ at item The program counter: @code{$pc}
+ at item The status register: @code{$ps}
+ at item The program counter at the beginning of the most recently executed
+instruction: @code{$pcc}
+ at item The user stack pointer: @code{$usp}
+ at item The supervisor stack pointer: @code{$ssp}
+ at item The source function code register: @code{$sfc}
+ at item The destinaton function code register: @code{$dfc}
+ at item The vector base register: @code{$vbr}
+ at item The fault address register: @code{$far}
+ at item The BDM temporary register: @code{$atemp}
+ at item The module base address register: @code{$mbar}
+ at end itemize
+Target processor interrupts are disabled during single-step (step, next,
+stepi, nexti) operations.
 @c OBSOLETE @node M88K
 @c OBSOLETE @subsection M88K
 @c OBSOLETE
diff -urN gdb-5.3/gdb/remote-m68k-bdm.c gdb-5.3-cfbdm/gdb/remote-m68k-bdm.c
--- gdb-5.3/gdb/remote-m68k-bdm.c	1969-12-31 17:00:00.000000000 -0700
+++ gdb-5.3-cfbdm/gdb/remote-m68k-bdm.c	2003-03-05 15:30:18.000000000 -0700
@@ -0,0 +1,1681 @@
+ * Motorola Background Debug Mode Target
+ * Copyright (C) 2000  Bryan Feir (bryan at sgl.crestech.ca)
+ * Based on:
+ *     Canada, 1993.
+ *     107 North Road
+ *     S7N 5C6
+ *  4. Coldfire support added by C Johns.
+ *  5. Hardware breakpoint support added by B Feir.
+ * W. Eric Norum
+ * 107 North Road
+ * S7N 5C6
+ * eric at skatter.usask.ca
+ * Coldfire support by:
+ * Chris Johns
+ * Objective Design Systems
+ * 35 Cairo Street
+ * Cammeray, Sydney, 2062, Australia
+ * ccj at acm.org
+ * Coldfire hardware breakpoint support by:
+ * Bryan Feir
+ * CRESTech (Centre for Research in Earth and Space Technology)
+ * 4850 Keele Street, 1st floor
+ * Toronto, Ontario, CANADA   M6E 3E5
+ * bryan at sgl.crestech.ca
+ * $Revision: 1.1 $    $Date: 2002/11/01 19:45:32 $   $Author: glikely $
+#include "defs.h"
+#include "gdbcore.h"
+#include "target.h"
+#include <unistd.h>
+#include <stdlib.h>
+#include <stdarg.h>
+#include <errno.h>
+#include <signal.h>
+#include <string.h>
+#include <stdio.h>
+#include <fcntl.h>
+#include <ctype.h>
+#include <sys/types.h>
+#include <sys/ioctl.h>
+#include <sys/time.h>
+#include "command.h"
+#include "inferior.h"
+#include "value.h"
+#include "breakpoint.h"
+#include "BDMlib.h"
+extern struct target_ops bdm_ops;	/* Forward declaration */
+ * The name of the BDM driver special file
+static char *dev_name;
+static int cpu_type;
+ * The different register names for the processors.
+static const char *cpu32plus_reg_names[NUM_REGS] = {
+ "d0", "d1", "d2", "d3", "d4", "d5", "d6", "d7",
+ "a0", "a1", "a2", "a3", "a4", "a5", "fp", "sp",
+ "ps", "pc",
+ "pcc", "usp", "ssp", "sfc", "dfc", "atemp", "far",
+ "vbr",
+ NULL, NULL, NULL, NULL,
+ "mbar",
+ NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL,
+static const char *cpu32_reg_names[NUM_REGS] = {
+ "ps", "pc",
+ "pcc", "usp", "ssp", "sfc", "dfc", NULL, NULL,
+ "vbr",
+ NULL,
+static const char *cf_reg_names[NUM_REGS] = {
+ "ps", "pc",
+ "vbr",
+ "cacr", "acr0", "acr1", "rambar",
+ "mbar",
+ "csr", "aatr", "tdr", "pbr", "pbmr", "abhr", "ablr", "dbr", "dbmr",
+static const char **bdm_reg_names = cpu32plus_reg_names;
+const char *bdm_register_name(int i)
+	if ((i < 0) || (i >= NUM_REGS))
+		return NULL;
+	return bdm_reg_names[i];
+static int reg_to_dev_num[] =
+{ BDM_REG_SR,
+  BDM_REG_RPC,
+  BDM_REG_PCC,
+  BDM_REG_USP,
+  BDM_REG_SSP,
+  BDM_REG_SFC,
+  BDM_REG_DFC,
+  BDM_REG_ATEMP,
+  BDM_REG_FAR,
+  BDM_REG_VBR,
+  BDM_REG_CACR,
+  BDM_REG_ACR0,
+  BDM_REG_ACR1,
+  BDM_REG_RAMBAR,
+  BDM_REG_MBAR,
+  BDM_REG_CSR,
+  BDM_REG_AATR,
+  BDM_REG_TDR,
+  BDM_REG_PBR,
+  BDM_REG_PBMR,
+  BDM_REG_ABHR,
+  BDM_REG_ABLR,
+  BDM_REG_DBR,
+  BDM_REG_DBMR
+ * The name of the most recently loaded program
+static char *bdm_prog_loaded;
+ * default delay for interface
+#define	BDM_DEFAULT_DELAY	0
+static int bdm_delay = -1;
+ * does gdb wait or not, only valid for a Coldfire processor
+static int bdm_gdb_no_wait = 0;
+ * Hold BDM ATEMP register (CPU32 only).
+static unsigned long atemp;
+static int haveAtemp;
+static int hit_watchpoint;
+ * CF BDM Debug hardware version number.
+static unsigned long cf_debug_ver;
+ * Not sure if this is defined somewhere. Cannot see anywhere.
+extern int (*ui_loop_hook) (int);
+ * Forward declarations
+static void bdm_load (char *, int);
+ * give target time to come up after reset
+ * time in usec
+#define	TIME_TO_COME_UP	60000
+ * Downloader routines
+static int downLoaderReturn;
+static int downLoaderFirst;
+static unsigned long downLoadBaseAddress, downLoadStartAddress;
+static int bdmDebugLevel;
+static const char *downloadErrorString;
+static void
+downloadSection (bfd *abfd, sec_ptr sec, PTR ignore)
+	unsigned long dfc;
+	unsigned long address;
+	unsigned long nleft;
+	int count;
+	file_ptr offset;
+	char cbuf[1024];
+	 * See if the section needs loading
+	if (bdmDebugLevel)
+		printf_filtered ("Section flags:%#x", bfd_get_section_flags
(abfd, sec));
+	if ((downLoaderReturn < 0) ||
+			((bfd_get_section_flags (abfd, sec) &
SEC_HAS_CONTENTS) == 0) ||
+			((bfd_get_section_flags (abfd, sec) & SEC_LOAD) ==
0))
+		return;
+	address = bfd_section_lma (abfd, sec);
+		printf_filtered ("Section address:%#x", address);
+	if (downLoaderFirst && (bfd_get_section_flags (abfd, sec) &
SEC_CODE)) {
+		downLoadStartAddress = bfd_get_start_address (abfd);
+		downLoadBaseAddress = address;
+		downLoaderFirst = 0;
+			printf_filtered ("Start address:%#x	 Base
address:%#x", downLoadStartAddress, downLoadBaseAddress);
+	 * Set the appropriate destination address space
+	if (bfd_get_section_flags (abfd, sec) & SEC_CODE)
+		dfc = 0x6;	/* Supervisor program space */
+	else
+		dfc = 0x5;	/* Supervisor data space */
+	if (bdmWriteSystemRegister (BDM_REG_DFC, dfc) < 0) {
+		downLoaderReturn = -1;
+		return;
+	 * Load the section in `sizeof cbuf` chunks
+	nleft = bfd_get_section_size_before_reloc (sec);
+	if (nleft == 0)
+		return;
+	offset = 0;
+	while (nleft) {
+		if (nleft > sizeof cbuf)
+			count = sizeof cbuf;
+		else
+			count = nleft;
+		if (!bfd_get_section_contents (abfd, sec, cbuf, offset,
count)) {
+			downloadErrorString = "Error reading section
contents";
+			return;
+		if (bdmWriteMemory (address, cbuf, count) < 0) {
+			return;
+		address += count;
+		offset += count;
+		nleft -= count;
+ * Load an executable image into the target
+static int
+loadExecutable (const char *name)
+	bfd *abfd;
+	unsigned long l;
+	 * Make sure target is there
+	if (!bdmCheck ())
+		return -1;
+	 * Open and verify the file
+	bfd_init ();
+	abfd = bfd_openr (name, "default");
+	if (abfd == NULL) {
+		downloadErrorString = bfd_errmsg (bfd_get_error());
+		return -1;
+	if (!bfd_check_format (abfd, bfd_object)) {
+		downloadErrorString = "Not an object file";
+		return -1;
+	 * Save the destination function code register
+	if (bdmReadSystemRegister (BDM_REG_DFC, &dfc) < 0)
+		return -1;
+	 * Load each section of the executable file
+	downLoaderFirst = 1;
+	downLoaderReturn = 0;
+	bfd_map_over_sections (abfd, downloadSection, NULL);
+	if (downLoaderReturn < 0)
+		return -1;
+	 * Set up stack pointer and program counter
+	if ((bdmReadLongWord (downLoadBaseAddress, &l) < 0)
+	 || (bdmWriteSystemRegister (BDM_REG_SSP, l) < 0)
+	 || (bdmReadLongWord (downLoadBaseAddress+4, &l) < 0)
+	 || (bdmWriteSystemRegister (BDM_REG_RPC, l) < 0)
+	 || (bdmWriteSystemRegister (BDM_REG_VBR, downLoadBaseAddress) < 0)
+	 || (bdmWriteSystemRegister (BDM_REG_DFC, dfc) < 0))
+		return -1;
+	return 0;
+ * The breakpoint codes for the different processors
+static char cpu32_breakpoint[] = {0x4a, 0xfa};
+static char cf_breakpoint[] = {0x4a, 0xc8};
+static char *breakpointCode;
+static int breakpointSize;
+static int cf_init_watchpoints();
+/* Immediately after a function call, return the saved pc before the frame
+   is setup.  For uCLinux which uses a TRAP #0 for a system call we need to
+   read the first long word of the stack to see if the stack frame format
is
+   type 4 and the vector is 32 (0x4080), and the opcode at the PC is
+   "move.w #0x2700,sr". If it is then get the second long from the stack.
+CORE_ADDR
+m68k_bdm_saved_pc_after_call (frame)
+     struct frame_info *frame;
+	unsigned int op;
+	unsigned int eframe;
+	int          sp;
+	sp = read_register (SP_REGNUM);
+	eframe = read_memory_integer (sp, 2);
+	op = read_memory_integer (frame->pc, 4);
+	 * This test could break if some changes the syste call.
+	if (eframe == 0x4080 && op == 0x46fc2700)
+		return read_memory_integer (sp + 4, 4);
+	else
+		return read_memory_integer (sp, 4);
+unsigned char *m68k_bdm_breakpoint_from_pc (pcptr, lenptr)
+     CORE_ADDR *pcptr;
+     int *lenptr;
+	*lenptr = breakpointSize;
+	return breakpointCode;
+ * Short pause
+static void
+nap (int microseconds)
+	struct timeval tv;
+	tv.tv_sec = microseconds / 1000000;
+	tv.tv_usec = microseconds % 1000000;
+	select (0, NULL, NULL, NULL, &tv);
+ * Display error message and jump back to main input loop
+static void
+bdm_report_error (void)
+	error ("BDM error: %s", bdmErrorString ());
+ * Initialize bdm interface port
+static void
+bdm_init (int tty, char *arg)
+ * Return interface status
+static int
+bdm_get_status (void)
+	int status;
+	if ((status = bdmStatus ()) < 0)
+		bdm_report_error ();
+	return status;
+static void
+bdm_get_status_interactive (int pid, char *arg)
+	printf ("BDM status: 0x%x\n", bdm_get_status ());
+ * release chip: reset and disable bdm mode
+static void
+bdm_release_chip (void)
+	haveAtemp = 0;
+	registers_changed ();
+	if (bdmRelease () < 0)
+ * stop chip
+static void
+bdm_stop_chip (void)
+	if (bdmStop () < 0)
+ * Allow chip to resume execution
+static void
+bdm_go (void)
+	haveAtemp = 0;
+	if (bdmGo () < 0)
+ * Reset chip, enter BDM mode
+static void
+bdm_reset (void)
+	if (bdmReset () < 0)
+	nap (TIME_TO_COME_UP);
+ * step cpu32 chip: execute a single instruction
+ * This is complicated by the presence of interrupts.
+ * Consider the following sequence of events:
+ *    - User attempts to `continue' from a breakpoint.
+ *    - Gdb calls bdm_step_chip to single-step the instruction that
+ *      had been replaced by the BGND instruction.
+ *    - The target processor executes the instruction and stops.
+ *    - GDB replaces the instruction with a BGND instruction to
+ *      force a breakpoint the next time the instruction is hit.
+ *    - GDB calls bdm_go and the target resumes execution.
+ * This all seems fine, but now consider what happens when a interrupt
+ * is pending:
+ *    - The target processor does not execute the replaced instruction,
+ *      but rather executes the first instruction of the interrupt
+ *      service routine, then stops.
+ *    - The target finishes off the interrupt, and upon returing from
+ *      the interrupt generates another breakpoint!
+ * The solution is simple -- disable interrupts when single stepping.
+ * The problem then becomes the handling of instructions which involve
+ * the program status word!
+static void
+bdm_step_cpu32_chip (void)
+	unsigned long pc;
+	unsigned short instruction;
+	unsigned short immediate;
+	unsigned long d7;
+	unsigned long sr;
+	unsigned long nsr;
+	enum {
+	  op_other,
+	  op_ANDIsr,
+	  op_EORIsr,
+	  op_ORIsr,
+	  op_TOsr,
+	  op_FROMsr,
+	  op_FROMsrTOd7
+	} op;
+	 * Get the existing status register
+	if (bdmReadSystemRegister (BDM_REG_SR, &sr) < 0)
+	 * Read the instuction about to be executed
+	if ((bdmReadSystemRegister (BDM_REG_RPC, &pc) < 0)
+	 || (bdmReadWord (pc, &instruction) < 0))
+	 * See what operation is to be performed
+	if (instruction == 0x027C)
+		op = op_ANDIsr;
+	else if (instruction == 0x0A7C)
+		op = op_EORIsr;
+	else if (instruction == 0x007C)
+		op = op_ORIsr;
+	else if (instruction == 0x40C7)
+		op = op_FROMsrTOd7;
+	else if ((instruction & 0xFFC0) == 0x40C0)
+		op = op_FROMsr;
+	else if ((instruction & 0xFFC0) == 0x46C0)
+		op = op_TOsr;
+	else
+		op = op_other;
+	 * Set things up for the single-step operation
+	switch (op) {
+	case op_FROMsr:
+		 * It's storing the SR somewhere.
+		 * Store the SR in D7 and change the instruction
+		 * to save D7.  This fails if the addressing mode
+		 * is one of the esoteric modes that uses D7 as
+		 * and index register, but we'll just have to hope
+		 * that doesn't happen too often.
+		if ((bdmReadRegister (7, &d7) < 0)
+		 || (bdmWriteRegister (7, sr) < 0)
+		 || (bdmWriteWord (pc, 0x3007 |
+					((instruction & 0x38) << 3) |
+					((instruction & 0x07) << 9)) < 0))
+		break;
+	case op_ANDIsr:
+	case op_EORIsr:
+	case op_ORIsr:
+		 * It's an immediate operation to the SR -- pick up the
value
+		if (bdmReadWord (pc+2, &immediate) < 0)
+		break;
+	case op_TOsr:
+	case op_other:
+		break;
+	 * Ensure the step is done with interrupts disabled
+	if (bdmWriteSystemRegister (BDM_REG_SR, sr | 0x0700) < 0)
+	 * Do the single-step
+	if (bdmStep () < 0)
+	 * Get the ATEMP register since the following operations may
+	 * modify it.
+	if (bdmReadSystemRegister (BDM_REG_ATEMP, &atemp) < 0)
+	haveAtemp = 1;
+	 * Clean things up
+	switch (op) {
+	case op_FROMsr:
+		if ((bdmWriteRegister (7, d7) < 0)
+		 || (bdmWriteWord (pc, instruction) < 0)
+		 || (bdmWriteSystemRegister (BDM_REG_SR, sr) < 0))
+		break;
+	case op_FROMsrTOd7:
+		 || (bdmWriteRegister (7, (d7 & ~0xFFFF) | (sr & 0xFFFF)) <
0)
+		break;
+	case op_ANDIsr:
+		if (bdmWriteSystemRegister (BDM_REG_SR, sr & immediate) < 0)
+		break;
+	case op_EORIsr:
+		if (bdmWriteSystemRegister (BDM_REG_SR, sr ^ immediate) < 0)
+		break;
+	case op_ORIsr:
+		if (bdmWriteSystemRegister (BDM_REG_SR, sr | immediate) < 0)
+		break;
+	case op_TOsr:
+		break;
+	case op_other:
+		if ((bdmReadSystemRegister (BDM_REG_SR, &nsr) < 0)
+		 || (bdmWriteSystemRegister (BDM_REG_SR, (nsr & ~0x0700) |
(sr & 0x0700)) < 0))
+		break;
+static void
+bdm_step_chip (void)
+	 * The cpu32 is harder to step than the Coldfire.
+	if (cpu_type == BDM_CPU32) {
+		bdm_step_cpu32_chip();
+		return;
+ * true if runnable
+static int
+bdm_can_run (void)
+	return 1;
+static void
+bdm_setdelay(int delay)
+	if (bdmSetDelay (delay) < 0)
+static void
+bdm_setdelay_interactive (char *arg, int from_tty)
+	char *dummy;
+	if (!arg) {
+		if (bdm_delay >= 0)
+			printf_filtered("bdm_delay is %d", bdm_delay);
+		else
+			printf_filtered("using default delay %d",
BDM_DEFAULT_DELAY);
+	else {
+		bdm_delay = strtoul(arg, &dummy, 0);
+		bdm_setdelay (bdm_delay);
+static void
+bdm_setdebug_interactive (char *arg, int from_tty)
+	char *dummy;
+	if (arg) {
+		bdmDebugLevel = strtoul(arg, &dummy, 0);
+		bdmSetDebugFlag (bdmDebugLevel);
+	else
+		error ("Argument missing");
+static void
+bdm_setdriverdebug_interactive (char *arg, int from_tty)
+	char *dummy;
+	if (arg)
+		bdmSetDriverDebugFlag (strtoul(arg, &dummy, 0));
+	else
+static void
+bdm_set_no_wait (char *arg, int from_tty)
+	bdm_gdb_no_wait = 1;
+static void
+bdm_set_wait (char *arg, int from_tty)
+		error ("No wait mode is not supported on a CPU32");
+		return;
+	if (bdm_get_status ())
+		bdm_gdb_no_wait = 0;
+	else
+		error ("The target is running, please stop first");
+static void
+bdm_issue_stop (char *arg, int from_tty)
+	bdm_stop_chip ();
+ * Open a connection the target via bdm
+ * name is the devicename of bdm and the filename to be used
+ * used for communication.
+static void
+bdm_open (char *name, int from_tty)
+	char          *p;
+	int           version;
+	unsigned long csr;
+	if (bdmIsOpen ())
+		error ("Bdm is already open, must close it first");
+	if (name == NULL)
+		error ("Use `target bdm <DEVICE-NAME>' to use the bdm
target");
+	 * Find the first whitespace character after device and chop it off
+	for (p = name; (*p != '\0') && (!isspace (*p)); p++) ;
+	if ((*p == '\0') && (p == name))
+		error ("Please include the name the bdm port device.");
+	dev_name = savestring (name, p - name);
+	target_preopen (from_tty);
+	unpush_target (&bdm_ops);
+	if (bdmOpen (dev_name) < 0)
+	if (bdmStatus () & (BDM_TARGETPOWER | BDM_TARGETNC)) {
+		bdmClose ();
+		error ("Target or cable problem");
+	 * Ask the driver for it's version.
+	 * We are only interested in the major number when checking the
+	 * driver version number.
+	if (bdmGetDrvVersion (&version) < 0)
+	if ((version & 0xff00) != (BDM_DRV_VERSION & 0xff00)) {
+		printf_filtered ("Incorrect driver version, looking for
%i.%i and found %i.%i\n",
+					BDM_DRV_VERSION >> 8,
BDM_DRV_VERSION & 0xff,
+					version >> 8, version  & 0xff);
+		bdmClose ();
+		error ("Can't run with wrong BDM driver");
+	 * Get the processor type.
+	if (bdmGetProcessor (&cpu_type) < 0)
+	switch (cpu_type) {
+	case BDM_CPU32:
+		bdm_reg_names = cpu32_reg_names;
+		breakpointCode = cpu32_breakpoint;
+		breakpointSize = sizeof cpu32_breakpoint;
+		break;
+	case BDM_COLDFIRE:
+		bdm_reg_names = cf_reg_names;
+		breakpointCode = cf_breakpoint;
+		breakpointSize = sizeof cf_breakpoint;
+		cf_init_watchpoints();
+		 * Read the CSR register to determine the debug module
+		 * version.
+		if (bdmReadSystemRegister (BDM_REG_CSR, &csr) < 0)
+		cf_debug_ver = (csr >> 20) & 0x0f;
+		break;
+	default:
+		bdmClose ();
+		error ("Unknown processor type returned from the driver.");
+	push_target (&bdm_ops);
+	else
+		bdm_setdelay (BDM_DEFAULT_DELAY);
+	if (from_tty)
+		printf_filtered ("Remote %s connected to %s\n",
target_shortname, dev_name);
+		if (cpu_type == BDM_COLDFIRE)
+			printf_filtered (" Coldfire debug module version is
%d (%s)\n",
+					cf_debug_ver,
+					cf_debug_ver == 0 ? "5206(e)" :
"5307/5407(e)");
+ * Terminate current application and return to system prompt.
+ * On a target, just let the program keep on running
+static void
+bdm_kill (void)
+	if (bdm_get_status () & BDM_TARGETSTOPPED)
+		bdm_go ();
+        inferior_ptid = null_ptid;
+static void
+bdm_close (quitting)
+int quitting;
+	if (quitting)
+		bdm_kill ();
+	bdmClose ();
+ * _detach -- Terminate the open connection to the remote debugger.
+ * takes a program previously attached to and detaches it.
+ * We better not have left any breakpoints
+ * in the program or it'll die when it hits one.
+ * Close the open connection to the remote debugger.
+ * Use this when you want to detach and do something else
+ * with your gdb.
+static void
+bdm_detach (char *args, int from_tty)
+	pop_target ();		/* calls bdm_close to do the real work */
+ * _resume -- Tell the remote machine to resume.
+static void
+bdm_resume (ptid_t ptid, int step, enum target_signal sig)
+	if (step)
+		bdm_step_chip ();
+	else
+		bdm_go ();
+ * We have fallen into an exception supported by the runtime system.
+ * by executing a `breakpoint' instruction.
+static void
+analyze_exception (struct target_waitstatus *status)
+	unsigned long pc, sp;
+	unsigned short vec;
+	char opcode[20]; /* `big enough' */
+		if (bdmReadSystemRegister (BDM_REG_PCC, &pc) < 0)
+	else {
+		if (bdmReadSystemRegister (BDM_REG_RPC, &pc) < 0)
+		if (pc)
+			pc -= 2;
+	status->kind = TARGET_WAITKIND_STOPPED;
+	 * See if it was a `breakpoint' instruction
+	if (bdmReadMemory (pc, opcode, breakpointSize) < 0)
+	if (memcmp (breakpointCode, opcode, breakpointSize) == 0) {
+		if (bdmWriteSystemRegister (BDM_REG_RPC, pc) < 0)
+		status->value.sig = TARGET_SIGNAL_TRAP;
+		return;
+	 * FIXME: Why an illegal instruction signal ?
+	status->value.sig = TARGET_SIGNAL_ILL;
+static int sigintFlag;
+static void
+bdm_signal_handler (int s)
+	sigintFlag++;
+ * Wait until the remote machine stops, then return,
+ * storing status in status just as `wait' would.
+static ptid_t
+bdm_wait (ptid_t ptid, struct target_waitstatus *status)
+	int bdm_stat;
+	int detach = 0;
+	int ui_count = 0;
+	void (*ofunc) ();
+	hit_watchpoint = 0;
+	if (bdm_gdb_no_wait) {
+		status->value.sig = TARGET_SIGNAL_GRANT;
+		return inferior_ptid;
+	status->kind = TARGET_WAITKIND_EXITED;
+	status->value.integer = 0;
+	 * Catch SIGINT signals
+	sigintFlag = 0;
+	ofunc = signal (SIGINT, bdm_signal_handler);
+	 * A work around a problem with the 5206e processor. Not sure
+   * what the issue is. It could be the processor.
+	if (cpu_type == BDM_COLDFIRE && cf_debug_ver == 0)
+		nap (10000);
+	 * Wait here till the target requires service
+	while ((bdm_stat = bdm_get_status ()) == 0) {
+		ui_count = 0;
+		while (ui_count++ < 6) {
+			nap (50000);
+			/* N.B. The UI may destroy our world (for instance
by calling
+			   remote_stop,) in which case we want to get out of
here as
+			   quickly as possible.  It is not safe to touch
scb, since
+		  	 someone else might have freed it.  The ui_loop_hook
signals that
+			   we should exit by returning 1. */
+			if (ui_loop_hook)
+				detach = ui_loop_hook (0);
+			if (detach || sigintFlag)
+				bdm_stop_chip ();
+	signal (SIGINT, ofunc);
+	 * Determine why the target stopped
+	switch (bdm_stat) {
+	case BDM_TARGETNC:
+		status->value.integer = 9999;
+		break;
+	case BDM_TARGETPOWER:
+		status->value.sig = TARGET_SIGNAL_PWR;
+		break;
+	case BDM_TARGETRESET:
+		status->value.sig = TARGET_SIGNAL_ABRT;
+		break;
+	case BDM_TARGETSTOPPED:
+	case BDM_TARGETHALT:
+	case BDM_TARGETSTOPPED | BDM_TARGETHALT:
+		if (sigintFlag) {
+			status->value.sig = TARGET_SIGNAL_TSTP;
+		else {
+				if (!haveAtemp
+				 && (bdmReadSystemRegister (BDM_REG_ATEMP,
&atemp) < 0))
+				switch (atemp & 0xffff) {
+					case 0xffff:	/* double bus fault
+					status->kind =
TARGET_SIGNAL_BUS;
+					break;
+				case 0x0:	/* HW bkpt */
+					status->kind =
TARGET_SIGNAL_TRAP;
+					break;
+				case 0x1:	/* background mode */
+					analyze_exception (status);
+					break;
+				default:
+					printf_filtered ("bdm_wait: Unknown
atemp:%#lx\n", atemp);
+					status->kind =
+			else {
&csr) < 0)
+				if (csr & 0x08000000)  {                /*
double bus fault */
+					status->kind =
TARGET_SIGNAL_BUS;
+				else  {
+					if (csr & 0x04000000)  {
/* hardware trigger */
+						hit_watchpoint = 1;
+						status->kind =
TARGET_SIGNAL_TRAP;
+					else  {
+						if (csr & 0x01000000)  {
/* -BKPT signal */
+							status->kind =
TARGET_SIGNAL_TRAP;
+						else  {
+							if (csr &
0x02000000)  {    /* HALT/software bkpt */
+							else  {
printf_filtered ("bdm_wait: Unknown csr:%#lx",
csr);
+								status->kind
+		break;
+	default:
+		printf_filtered ("bdm_wait: Unknown BDM status: %#x",
bdm_stat);
+		break;
+	haveAtemp = 0;
+ * The following routines handle the Coldfire hardware breakpoints.  Only
one
+ * breakpoint supported so far, and it can be either a PC breakpoint or an
+ * address watchpoint.  Unfortunately, the
+ * macro only allows for bounds checking within one of the two types and
not
+ * limits that cover the sum of both, so extra work is needed.
+ * (Actually, very few processors seem to have much support for that
routine
+ * at all.)
+ * As a result, the way this is handled is that the can_use routine will
allow
+ * the first breakpoint of either type to be added.  Any further checking
so
+ * that only one of the two can be used is done later when GDB actually
tries
+ * to create the breakpoints, usually when the processor is restarted.
+ * We keep a local copy of the breakpoints list becasue the chain that GDB
+ * keeps isn't exported globally.
+ * While things could be simplified with only one breakpoint present,
setting
+ * up more general routines allows for later expansion if newer versions of
+ * the ColdFire chip support more breakpoints at once.
+ * Also, the ColdFire supports things like multi-level triggers and
triggers
+ * based on the data bus instead of just the address bus.  The GDB commands
+ * don't allow for access to this, but much of it isn't necessary anyway,
+ * as GDB has its own method of handling 'breakpoint conditions' that is
+ * sufficient for most tasks.
+#define TDR_TRC_DDATA 0x00000000
+#define TDR_TRC_HALT  0x40000000
+#define TDR_TRC_DINT  0x80000000
+#define TDR_L2_EBL    0x20000000
+#define TDR_L2_ALL    0x1FFF0000
+#define TDR_L2_EDLW   0x10000000
+#define TDR_L2_EDWL   0x08000000
+#define TDR_L2_EDWU   0x04000000
+#define TDR_L2_EDLL   0x02000000
+#define TDR_L2_EDLM   0x01000000
+#define TDR_L2_EDUM   0x00800000
+#define TDR_L2_EDUU   0x00400000
+#define TDR_L2_DI     0x00200000
+#define TDR_L2_EAI    0x00100000
+#define TDR_L2_EAR    0x00080000
+#define TDR_L2_EAL    0x00040000
+#define TDR_L2_EPC    0x00020000
+#define TDR_L2_PCI    0x00010000
+#define TDR_L1_EBL    0x00002000
+#define TDR_L1_ALL    0x00001FFF
+#define TDR_L1_EDLW   0x00001000
+#define TDR_L1_EDWL   0x00000800
+#define TDR_L1_EDWU   0x00000400
+#define TDR_L1_EDLL   0x00000200
+#define TDR_L1_EDLM   0x00000100
+#define TDR_L1_EDUM   0x00000080
+#define TDR_L1_EDUU   0x00000040
+#define TDR_L1_DI     0x00000020
+#define TDR_L1_EAI    0x00000010
+#define TDR_L1_EAR    0x00000008
+#define TDR_L1_EAL    0x00000004
+#define TDR_L1_EPC    0x00000002
+#define TDR_L1_PCI    0x00000001
+struct cf_break  {
+	enum target_hw_bp_type type;
+	CORE_ADDR   addr;
+	int         len;
+#define CF_BREAKPOINT_MAX 1
+static struct cf_break cf_breakpoints[CF_BREAKPOINT_MAX];
+static int cf_breakpoint_count;
+static int
+cf_init_watchpoints(void)
+	if (cpu_type != BDM_COLDFIRE)  {
+		return(-1);
+	cf_breakpoint_count = 0;
+	if (bdmWriteSystemRegister (BDM_REG_TDR, TDR_TRC_HALT) < 0)
+	return(0);
+int
+cf_stopped_by_watchpoint(void)
+	return hit_watchpoint;
+int
+cf_can_use_watchpoint(type, cnt, ot)
+	int cnt;
+	int ot;
+	unsigned long tdr;
+		return(0);
+	if (type == bp_hardware_breakpoint || type == bp_read_watchpoint ||
+	    type == bp_hardware_watchpoint || type == bp_access_watchpoint)
+		if (cnt <= 1)  {
+			return(1);
+	return(-1);
+int
+cf_insert_hw_breakpoint(addr, shadow)
+	CORE_ADDR addr;
+	char *shadow;
+		return(-1);
+	if (cf_breakpoint_count < CF_BREAKPOINT_MAX)  {
+		cf_breakpoints[cf_breakpoint_count].type = hw_execute;
+		cf_breakpoints[cf_breakpoint_count].addr = addr;
+		cf_breakpoints[cf_breakpoint_count++].len = 2;
+		if (bdmReadSystemRegister (BDM_REG_TDR, &tdr) < 0)
+		tdr = ((tdr & ~TDR_L1_ALL) | (TDR_L1_EBL|TDR_L1_EPC));
+		if (bdmWriteSystemRegister (BDM_REG_PBR, addr) < 0)
+		if (bdmWriteSystemRegister (BDM_REG_PBMR, 0) < 0)
+		if (bdmWriteSystemRegister (BDM_REG_TDR, tdr) < 0)
+			printf_filtered ("Insert PC Breakpoint @0x%08x\n",
addr);
+	else  {
+		return(-1);
+	return(0);
+static int
+cf_check_breakpoint(type, addr, len)
+	CORE_ADDR addr;
+	int len;
+	int i;
+	for (i = 0; i < cf_breakpoint_count; i++)  {
+		if (cf_breakpoints[i].type == type &&
+		    cf_breakpoints[i].addr == addr &&
+		    cf_breakpoints[i].len == len)  {
+			for (; i < CF_BREAKPOINT_MAX-1; i++)  {
+				cf_breakpoints[i] = cf_breakpoints[i+1];
+			cf_breakpoint_count--;
+			return(1);
+	return(0);
+int
+cf_remove_hw_breakpoint(addr, shadow)
+	CORE_ADDR addr;
+	char *shadow;
+		return(-1);
+	if (cf_check_breakpoint(hw_execute, addr, 2))  {
+		tdr &= ~TDR_L1_EPC;
+		if ((tdr & TDR_L1_ALL) == 0)  {
+			tdr &= ~TDR_L1_EBL;
+			printf_filtered ("Remove PC Breakpoint @0x%08x\n",
addr);
+	else  {
+		return(-1);
+	return(0);
+#define AATR_READONLY  0x7F85
+#define AATR_WRITEONLY 0x7F05
+#define AATR_READWRITE 0xFF05
+int
+cf_insert_watchpoint(addr, len, type)
+	CORE_ADDR addr;
+	int len;
+		return(-1);
+		cf_breakpoints[cf_breakpoint_count].type = type;
+		cf_breakpoints[cf_breakpoint_count++].len = len;
+		tdr = ((tdr & ~TDR_L1_ALL) | (TDR_L1_EBL|TDR_L1_EAR));
+		if (bdmWriteSystemRegister (BDM_REG_ABLR, addr) < 0)
+		if (bdmWriteSystemRegister (BDM_REG_ABHR, addr+len-1) < 0)
+		if (type == hw_read)  {
+			if (bdmWriteSystemRegister (BDM_REG_AATR,
AATR_READONLY) < 0)
+				printf_filtered ("Insert read Watchpoint
@0x%08x-0x%08x\n",
+				                 addr, addr+len-1);
+		else if (type == hw_write)  {
AATR_WRITEONLY) < 0)
+				printf_filtered ("Insert write Watchpoint
@0x%08x-0x%08x\n",
+		else  {
AATR_READWRITE) < 0)
+				printf_filtered ("Insert access Watchpoint
@0x%08x-0x%08x\n",
+	else  {
+		return(-1);
+	return(0);
+int
+cf_remove_watchpoint(addr, len, type)
+	CORE_ADDR addr;
+	int len;
+		return(-1);
+	if (cf_check_breakpoint(type, addr, len))  {
+		tdr &= ~TDR_L1_EAR;
+			printf_filtered ("Remove %s Watchpoint
@0x%08x-0x%08x\n",
+			                 (type == hw_read) ? "read" :
+			                  ((type == hw_write) ? "write" :
"access"),
+	else  {
+		return(-1);
+	return(0);
+int
+cf_stopped_data_address()
+	unsigned long ablr;
+		return(-1);
+	if (bdmReadSystemRegister (BDM_REG_ABLR, &ablr) < 0)
+	if (tdr & TDR_L1_EAR)  {
+		return(ablr);
+	return(0);
+/* This is called not only when we first attach, but also when the
+   user types "run" after having attached.  */
+void
+bdm_create_inferior (char *execfile, char *args, char **env)
+	char *prg_file = NULL;
+	unsigned long entry_pt;
+	clear_proceed_status ();
+	init_wait_for_inferior ();
+	if (*args) {
+		prg_file = args;
+	else {
+		prg_file = execfile;
+	if (!(prg_file) && !(bdm_prog_loaded))
+		error ("No program specified to run\n");
+	if (bdm_prog_loaded)
+		printf_filtered ("Note: `%s' has already been loaded.\n",
bdm_prog_loaded);
+	if (query ("Do you want to download `%s'?", prg_file))
+		bdm_load (prg_file, 0);
+	if (bdmReadSystemRegister (BDM_REG_RPC, &entry_pt) < 0)
+	proceed (entry_pt, TARGET_SIGNAL_DEFAULT, 0);
+        inferior_ptid = pid_to_ptid (0);
+ * Fetch register REGNO, or all user registers if REGNO is -1.
+static void
+bdm_fetch_register (int regno)
+	unsigned long l;
+	char cbuf[4];
+	int ret;
+	if (regno < 0) {
+		for (regno = 0 ; regno < NUM_REGS ; regno++)
+			bdm_fetch_register (regno);
+	else {
+		 * When the target is running the
+		 * cpu registers can not be accessed.
+		if (bdm_gdb_no_wait && (bdm_get_status () == 0)) {
+			l = 0;
+			ret = 0;
+		else {
+			if (regno < 16) {
+				ret = bdmReadRegister (regno, &l);
+			else {
+				if ((regno - 16) < (sizeof (reg_to_dev_num)
/ sizeof (int))) {
+					ret = bdmReadSystemRegister
(reg_to_dev_num[regno - 16], &l);
+				else {
+					error ("Bad register number (%d)",
regno);
+					return;
+		if (ret < 0)
+		cbuf[0] = l >> 24;
+		cbuf[1] = l >> 16;
+		cbuf[2] = l >> 8;
+		cbuf[3] = l;
+		supply_register (regno, cbuf);
+void
+bdm_prepare_to_store (void)
+	/* Do nothing, since we can store individual regs */
+ * Store register REGNO, or all user registers if REGNO == -1.
+void
+bdm_store_register (int regno)
+	unsigned long l;
+	int ret;
+		return;
+	if (regno == -1) {
+			bdm_store_register (regno);
+	else {
+		l = read_register (regno);
+		if (regno < 16) {
+			ret = bdmWriteRegister (regno, l);
+		else {
+			if ((regno - 16) < (sizeof (reg_to_dev_num) / sizeof
(int))) {
+				ret = bdmWriteSystemRegister
(reg_to_dev_num[regno - 16], l);
+			else {
+				error ("Bad register number (%d)", regno);
+				return;
+		if (ret < 0)
+ * Transfer memory contents between target and host
+static int
+bdm_xfer_inferior_memory (CORE_ADDR memaddr, char *myaddr, int len, int
write, struct mem_attrib *attrib, struct target_ops *t)
+	int ret;
+	if (write)
+		ret = bdmWriteMemory (memaddr, myaddr, len);
+	else
+		ret = bdmReadMemory (memaddr, myaddr, len);
+	if (ret < 0)
+	return len;
+static void
+bdm_files_info (struct target_ops *t)
+	printf_filtered ("target %s is attached to %s\n", t->to_shortname,
dev_name);
+	if (bdm_prog_loaded) {
+		printf_filtered ("and running program %s\n",
bdm_prog_loaded);
+	else {
+		printf_filtered ("no program loaded\n");
+ * Load a file.
+static void
+bdm_load (char *args, int from_tty)
+	char *p;
+		free (bdm_prog_loaded);
+		bdm_prog_loaded = NULL;
+	if (!args) {
+		error (
+		 "The bdmload command must include the filename to load.\n"
+			     "You may want to use 'run', which uses the file
given\n"
+				 "on the command line when gdb was
invoked.");
+	if ((bdm_get_status () & BDM_TARGETSTOPPED) == 0)
+		bdm_stop_chip ();
+	/* strip off additional (unwanted) arguments after file name */
+	for (p = args; (*p != '\0') && (!isspace (*p)); p++) ;
+	*p = '\0';
+	if (loadExecutable (args) < 0)
+		error ("%s", downloadErrorString);
+	bdm_prog_loaded = savestring (args, strlen (args));
+ * Select a CPU32 processor register set.
+static void
+bdm_select_cpu32 (char *args, int from_tty)
+struct target_ops bdm_ops;
+static void
+init_bdm_ops(void)
+	bdm_ops.to_shortname = "bdm";
+	bdm_ops.to_longname = "CPU32 and Coldfire Background Debug Mode
Interface for downloading and remote debugging";
+	bdm_ops.to_doc = "Uses the Public Domain Background Debug Mode
Interface connected to the\n"
+"BDM-port of the CPU32 or Coldfire based microcontroller and to a parallel
port\n"
+"of the PC.\n"
+"Usage: target bdm <device>\n"
+"where <device> is the BDM character special file (e.g. /dev/bdm0).";
+	bdm_ops.to_open = bdm_open;
+	bdm_ops.to_close = bdm_close;
+	bdm_ops.to_detach = bdm_detach;
+	bdm_ops.to_resume = bdm_resume;
+	bdm_ops.to_wait = bdm_wait;
+	bdm_ops.to_fetch_registers = bdm_fetch_register;
+	bdm_ops.to_store_registers = bdm_store_register;
+	bdm_ops.to_prepare_to_store = bdm_prepare_to_store;
+	bdm_ops.to_xfer_memory = bdm_xfer_inferior_memory;
+	bdm_ops.to_files_info = bdm_files_info;
+	bdm_ops.to_insert_breakpoint = memory_insert_breakpoint;
+	bdm_ops.to_remove_breakpoint = memory_remove_breakpoint;
+	bdm_ops.to_kill = bdm_kill;
+	bdm_ops.to_load = bdm_load;
+	bdm_ops.to_create_inferior = bdm_create_inferior;
+	bdm_ops.to_mourn_inferior = generic_mourn_inferior;
+	bdm_ops.to_can_run = bdm_can_run;
+	bdm_ops.to_stratum = process_stratum;
+	bdm_ops.to_has_all_memory = 1;
+	bdm_ops.to_has_memory = 1;
+	bdm_ops.to_has_stack = 1;
+	bdm_ops.to_has_registers = 1;
+	bdm_ops.to_has_execution = 1;
+	bdm_ops.to_magic = OPS_MAGIC;
+void
+_initialize_remote_bdmcf (void)
+	init_bdm_ops ();
+	add_com ("bdm_reset", class_obscure,
+		 (void (*)(char *, int))bdm_reset,
+		 "Reset target and enter BDM mode.");
+	add_com ("bdm_release", class_obscure,
+		 (void (*)(char *, int))bdm_release_chip,
+		 "Reset target without BDM-mode.");
+	add_com ("bdm_status", class_obscure,
+		 (void (*)(char *, int))bdm_get_status_interactive,
+		 "Show status of bdm interface\n");
+	add_com ("bdm_setdelay", class_obscure,
+		 bdm_setdelay_interactive,
+		 "set delay for download");
+	add_com ("bdm_setdebug", class_obscure,
+		 bdm_setdebug_interactive,
+		 "enable/disable BDM diagnostic messages");
+	add_com ("bdm_setdriverdebug", class_obscure,
+		 bdm_setdriverdebug_interactive,
+		 "enable/disable BDM driver diagnostic messages");
+	add_com ("bdm_no_wait", class_obscure,
+		 bdm_set_no_wait,
+		 "Cause GDB to not wait for the target to stop when
running.");
+	add_com ("bdm_wait", class_obscure,
+		 bdm_set_wait,
+		 "Cause GDB to wait for the target to stop when running.");
+	add_com ("bdm_stop", class_obscure,
+		 bdm_issue_stop,
+		 "Stop the target if running.");
+	add_com ("bdm-select-cpu32", class_obscure,
+		 bdm_select_cpu32,
+		 "Selects the CPU32 register set rather than the default
CPU32+.");
+	add_target (&bdm_ops);
