unable to make install under cygwin
Kamen Penev kamen at penev.net
Wed Mar 12 01:04:33 UTC 2003
Perhaps you did "configure --prefix=//opt/rtems" by mistake? I built
ss-20021118 under cygwin, no problem.
Kamen
Angelo Fraietta wrote:
> I am unable to make and install RTEMS under cygwin.
> If I do a make all, RTEMS builds (the samples still don't work
> though); however, if I do a make install, I get the following failure:
> /usr/nin/install: cannot create regular file
> //opt/rtems/i386-rtems/pc386/lib " no such host or network
> I believe the problem is that is is trying to go to //opt instead of
> /opt  Is there anything special I need to do in the configure for cygwin?
