unable to make install under cygwin
Angelo Fraietta
angelo_f at bigpond.com
Wed Mar 12 02:09:01 UTC 2003
Joel Sherrill wrote:
>Angelo Fraietta wrote:
>>I am unable to make and install RTEMS under cygwin.
>>If I do a make all, RTEMS builds (the samples still don't work though);
>>however, if I do a make install, I get the following failure:
>>/usr/nin/install: cannot create regular file
>>//opt/rtems/i386-rtems/pc386/lib " no such host or network
>>I believe the problem is that is is trying to go to //opt instead of /opt
>>Is there anything special I need to do in the configure for cygwin?
>I downloaded over the weekend to my home computer and did a
>"native" Cygwin build without problems.
>I think you are right that // is special in Cygwin. Can you tell
>from the logs where it started to come from? I believe it is looking
>for the host named "opt". :(
The error is occuring when it says
make install-data-hook
the command says makedir -p //opt/rtems/i386-rtems/pc386/lib
I have had a look in the makefile and it has
install-data-hook: $(LIB)
@$(mkinstalldirs) $(DESTDIR)/$(libdir)
$(INSTALL_DATA) $(LIB) $(DESTDIR)/$(libdir)
I have found in that libdir defined inthe makefile as
libdir = ${exec_prefix}/pc386/lib
however DESTDIR is not defined anywhere in that file
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
URL: <http://lists.rtems.org/pipermail/users/attachments/20030312/084a807c/attachment.html>
