Building latest tools for Coldfire
Mike Siers
mikes at poliac.com
Wed Mar 12 16:53:12 UTC 2003
Hi,
I have an older Coldfire bsp that I want to get working
with the latest RTEMS snapshot. I am using OpenBSD as
my host system so I need to build the tools from the
source code. I have successfully built the tools for both
the i386 and arm platforms but I have a few questions about
the m68k/coldfire platform.
1) Are there any specific patches that I should use for the
Coldfire with the latest gnu tools?
2) Is there a way to tell gcc to only build support for the
Coldfire processor? I am just trying to save some time in
compiling gcc.
3) What configure options should I be using to build gcc?
I used the options below but when I link I noticed that
the crti.o and crtn.o files were not built and copied to
the appropriate spot. I built the files manually but
my application is dying at startup time.
../gcc-3.2.1/configure --target=m68k-rtems --with-gnu-ld
--with-gnu-as --with-newlib
--enable-threads --prefix=/opt/rtems
Any thoughts, comments, or hints would be greatly appreciated.
Thanks
Mike Siers
