_CORE_mutex_Seize
Wendell Thompson
wthompson at dsg-test.com
Fri Mar 14 00:04:43 UTC 2003
My application using code from the ppp example calls
rtems_bsdnet_semaphore_obtain, which then calls _Core_mutex_Seize, which
then goes directly into _CORE_mutex_Seize_interrupt_blocking. It then
swaps tasks and never returns to that task.
Shouldn't _CORE_mutex_Seize go into _CORE_mutex_Seize_interrupt_trylock?
It appears that rtems_glue.c was built with __RTEMS_APPLICATION__ defined.
This is 4.6.0pre1, built for an M68k custom bsp.
