CD build with ACE problems
Jack Cawkwell J.Cawkwell at open.ac.uk
Mon Mar 17 12:12:23 UTC 2003
Hi,
I am trying to build ACE under rtems, but I have problems.
The first file that is compiled reports an error because
clockid_t is not defined. Is this a common compilation
problem with an obvious solution? It appears to me that the
compiler gets into a state where it can nolonger parse
legal code in :
/opt/rtems/i386-rtems/include/sys/types.h circa line 245
if I add
        typedef anything int;
before the offending line:
        typedef _CLOCKID_T clockid_t;
it fails on the added line, which should compile just about anywhere?
i386-rtems-g++ and
i386-rtems-cpp newlib-1.11.0-20030203 2
I am using ACE version 5.3, the latest stable, it is much more
recent that the 5.1.14 that was previously compiled.
Any ideas? Jack
