(Fwd) Re: DOSFS bug fixes, IDE drivers and sample released
Angelo Fraietta
angelo_f at bigpond.com
Fri Mar 21 00:46:08 UTC 2003
I got the program working and it worked fine with my flash disk.
I did, however, have to type my filenames in UPPER CASE. I don't know
whether this is something peculiar with the DIMMPC flash IDE or not.
I also modified so I wrote a binary stream from 0x00 to 0xFF and tested
that it was uncorrupted. That worked fine too.
So effectively, this is working fine for me.
Do you know whether this will be included in the next snapshot?
Thomas Doerfler wrote:
>Hello,
>no it has nothing to do with ada, it is a web-
>based bug tracking system. Just try it out,
>login/password is guest/guest...
>wkr,
> Thomas.
>>Is the gnats system only ada? I am using C/C++, so will I be able to use
>>these?
>>>Hello Angelo,
>>>the "sample" program is located in the patch filed in the gnat
>>>system as PR369. So if you go to
>>>http://www.oarcorp.com/cgi-bin/gnatsweb.pl
>>>and inspect PR369 and download/apply the patch and then look
>>>into c/src/tests/samples/fileio, you will see the sample
>>>application.
>>>BTW, you will also need PR368 and PR367 to get everything
>>>running (these PRs contain modifications for the DOSFS code
>>>and added drivers for PC386 and MBX8xx).
>>>wkr,
>>> Thomas.
>>Angelo Fraietta
>>PO Box 859
>>Hamilton NSW 2303
>>Home Page
>>http://www.users.bigpond.com/angelo_f/
>>There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
>>There are those who seek knowledge to be known by others - that is VANITY
>>There are those who seek knowledge in order to serve - that is LOVE
>> Bernard of Clairvaux (1090 - 1153)
>IMD Ingenieurbuero fuer Microcomputertechnik
>Thomas Doerfler Herbststrasse 8
>D-82178 Puchheim Germany
>email: Thomas.Doerfler at imd-systems.de
>PGP public key available at: http://www.imd-
>systems.de/pgp_keys.htm
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
URL: <http://lists.rtems.org/pipermail/users/attachments/20030321/4458cfab/attachment.html>
