Internal compiler error building an m68k BSP with VARIANT=DEBUG
Matt Cross matt at dragonflyhollow.org
Fri Mar 21 03:38:17 UTC 2003
I'm working with the mrm332 m68k BSP.  I can build it fine with the normal
(optimized) variant, but when I build it with VARIANT=DEBUG, I get the
following compiler error trying to compile
cpukit/libmisc/capture/capture-cli.c:
../../../../../../../rtems-src/cpukit/libmisc/capture/capture-cli.c: In
function `rtems_capture_task_time':
../../../../../../../rtems-src/cpukit/libmisc/capture/capture-cli.c:1403:
Internal compiler error in instantiate_virtual_regs_1, at function.c:3974
Please submit a full bug report,
with preprocessed source if appropriate.
See <URL:http://www.gnu.org/software/gcc/bugs.html> for instructions.
I am one step behind on gcc (I'm using
m68k-rtems-gcc-gcc3.2.1newlib1.11.0-1.i386.rpm, the latest is
m68k-rtems-gcc-gcc3.2.1newlib1.11.0-2.i686.rpm), because the machine I'm
using is an AMD K6 and the i686 rpm doesn't work on it.  Were any bugs
like this fixed in between the -1 and -2 versions?  Is anyone else seeing
this?
Thanks,
    -Matt
