(Fwd) Re: DOSFS bug fixes, IDE drivers and sample released
Angelo Fraietta
angelo_f at bigpond.com
Sun Mar 23 11:14:50 UTC 2003
Joel Sherrill wrote:
> Angelo Fraietta wrote:
>> I got the program working and it worked fine with my flash disk.
>> I did, however, have to type my filenames in UPPER CASE. I don't know
>> whether this is something peculiar with the DIMMPC flash IDE or not.
>> I also modified so I wrote a binary stream from 0x00 to 0xFF and
>> tested that it was uncorrupted. That worked fine too.
>> So effectively, this is working fine for me.
>> Do you know whether this will be included in the next snapshot?
> Are you specifically referring to the test application or some
> particular patch set?
I mean the test application (which I modified) that came with the patch set
This is the set (copied from previous email)
the "sample" program is located in the patch filed in the gnat
system as PR369. So if you go to
http://www.oarcorp.com/cgi-bin/gnatsweb.pl and inspect PR369 and
download/apply the patch and then look into
c/src/tests/samples/fileio, you will see the sample application.
BTW, you will also need PR368 and PR367 to get everything running
(these PRs contain modifications for the DOSFS code and added
drivers for PC386 and MBX8xx).
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
URL: <http://lists.rtems.org/pipermail/users/attachments/20030323/96657e52/attachment.html>
