question of telnet daemon
Fernando RUIZ
correo at fernando-ruiz.com
Wed Mar 5 08:24:46 UTC 2003
"jeab" wrote:
> Thank you for your answer.
> To patch, Where can i find patch file ??
> I trying www.rtems.com site, but they ask userid,password.
> thanks.
> Ûiÿù+¦-¢Ì
¢oá¶Úý«¢Ì
¢Jÿjëh³
Hi,
After install the lastest snapshot you can find all the sources for telnetd in libmisc/. And
shell at shell/ too.
The telnet version is a very poor implementation to give a remote console for several users
simultaneously like linux console environment.
You need to setup the networking and after this to call to rtems_telnetd() daemon.
The telnetd daemon calls to shell() to give a command line prompt.
Two users are valid 'root' and 'user' with root privileges and user privileges. No password
required.
You can browse the rtems_telnetd() sources in order to add new shell commands at your project.
All the rtems_monitor commands are wrapped giving a path to spy the rtems kernel status.
Tasks, memory and more...
Adding rtems_telnetd() at your application you have automaticaly ip status, tcp status, route
status, etc... Nothig is necesary to add this. Only call rtems_telnetd().
You can call shell() directly giving a '/dev/chardevice' termios compatible device. The
/dev/ttyS0 for the pc386 bsp is a good example.
With this you can inspect the rtems status without tcp enabled.
I have made an example to start the ftpd or telnetd at demand after a serial console prompt.
With this I have could inspect all the rtems internal status before the tcp/ip stack start.
Very cool to learn the rtems tricks.
Don't hesitate to ask me any question. I am not a tcp/ip expert but I am a rtems user with some
experience in this concern.
Till Stauman has worked very hard to give a telnetd interface like standards demand.
He has a very powerfull shell. You can find it at the contributions directory.
BRDS
Fernando RUIZ
(Sorry but my English isn't so good, My spanish is better)
