unable to make install under cygwin
Angelo Fraietta angelo_f at bigpond.com
Wed Mar 12 01:19:51 UTC 2003
Kamen Penev wrote:
> Perhaps you did "configure --prefix=//opt/rtems" by mistake? I built
> ss-20021118 under cygwin, no problem.
> Kamen
Definately not. I checked this a few times. Did you also do make all
install? The build worked but not the install.
Could you do me a favour and email me a copy of the ticker example from
the samples directory (if you did a pc386 build of RTEMS)
Thanks
> Angelo Fraietta wrote:
>> I am unable to make and install RTEMS under cygwin.
>> If I do a make all, RTEMS builds (the samples still don't work
>> though); however, if I do a make install, I get the following failure:
>> /usr/nin/install: cannot create regular file
>> //opt/rtems/i386-rtems/pc386/lib " no such host or network
>> I believe the problem is that is is trying to go to //opt instead of
>> /opt  Is there anything special I need to do in the configure for
>> cygwin?
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
    Bernard of Clairvaux (1090 - 1153)
