(Fwd) Re: DOSFS bug fixes, IDE drivers and sample released
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Tue Mar 18 21:15:41 UTC 2003
Hello,
no it has nothing to do with ada, it is a web-
based bug tracking system. Just try it out,
login/password is guest/guest...
wkr,
Thomas.
> Is the gnats system only ada? I am using C/C++, so will I be able to use
> these?
> Thomas Doerfler wrote:
> >Hello Angelo,
> >the "sample" program is located in the patch filed in the gnat
> >system as PR369. So if you go to
> >http://www.oarcorp.com/cgi-bin/gnatsweb.pl
> >and inspect PR369 and download/apply the patch and then look
> >into c/src/tests/samples/fileio, you will see the sample
> >application.
> >BTW, you will also need PR368 and PR367 to get everything
> >running (these PRs contain modifications for the DOSFS code
> >and added drivers for PC386 and MBX8xx).
> >wkr,
> > Thomas.
> Angelo Fraietta
> PO Box 859
> Hamilton NSW 2303
> Home Page
> http://www.users.bigpond.com/angelo_f/
> There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
> There are those who seek knowledge to be known by others - that is VANITY
> There are those who seek knowledge in order to serve - that is LOVE
> Bernard of Clairvaux (1090 - 1153)
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-
systems.de/pgp_keys.htm
