CD build with ACE problems
Wed Mar 19 12:50:45 UTC 2003
Jack Cawkwell wrote:
>Joel,
>I looked at my build and you are correct. Don't now how that happened,
>but I will try deleting everything but the current version and rebuild
>everything.
I'm just glad that's all it was.  These type of problems always worry me.
>Thanks Jack
>Joel Sherrill <joel.sherrill at oarcorp.com> writes:
>>>Hi,
>>>I am trying to build ACE under rtems, but I have problems.
>>>The first file that is compiled reports an error because
>>>clockid_t is not defined. Is this a common compilation
>>>problem with an obvious solution? It appears to me that the
>>>compiler gets into a state where it can nolonger parse
>>>legal code in :
>>>/opt/rtems/i386-rtems/include/sys/types.h circa line 245
>>>if I add
>>>        typedef anything int;
>>>before the offending line:
>>>        typedef _CLOCKID_T clockid_t;
>>>it fails on the added line, which should compile just about anywhere?
>>>i386-rtems-g++ and
>>>i386-rtems-cpp newlib-1.11.0-20030203 2
>>>I am using ACE version 5.3, the latest stable, it is much more
>>>recent that the 5.1.14 that was previously compiled.
>>>Any ideas? Jack
>>This usually indicates that the C library and RTEMS are out of sync.
>>It used to occur when transitioning from a 4.5.0 toolset to a
>>snapshot one.  Are you sure about which version of the tools you
>>are using?
>>--joel
